fifth gear poppin out!!!!! help please!
so i have a b16a2 with a gsr tranny....the swap was done over a year ago with absolutely no problems....just about 2 weeks ago i was cruisin on the freeway home from work in fifth gear and it just popped out....no grind or anything...just popped out...and now about every 5 miles or so it does this....it doesnt seem to be a syncro cuz it would grind right??? please anyone give me some info....thanks
Re: fifth gear poppin out!!!!! help please! (carter628)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carter628 »</TD></TR><TR><TD CLASS="quote">so i have a b16a2 with a gsr tranny....the swap was done over a year ago with absolutely no problems....just about 2 weeks ago i was cruisin on the freeway home from work in fifth gear and it just popped out....no grind or anything...just popped out...and now about every 5 miles or so it does this....it doesnt seem to be a syncro cuz it would grind right??? please anyone give me some info....thanks</TD></TR></TABLE>
It sounds like the syncro . What else would pop it out like that?
Lemme go find bense or mistabone for ya .
EDIT:
Unless you bent the 5th/R fork - did you have an "incident" with it recently?
EDIT:
Ek Forever y0!
Have you checked your fluid?
It could possibly be your synchros, but if you haven't changed the fluid since the swap, go ahead and change it.
Re: (Bense)
today i will change fluid after work....i did change it about 5 or 6 months ago......and i havent had incident and the mounts are fine....i will keep you posted....thank you guys....
B A N N E D
dang, hope it dont end up like my old d15b7 tranny...lol...i had to hold it in every gear except 1st gear...lol or else it would pop right out soon as ilet off the gas pedal
Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">how are your mounts looking?
synchros have nothing to do with the gear disengaging, only the gear engagement.</TD></TR></TABLE>
Ah, I C
Ah, I C
Re: (Syndacate)
ok so when i replaced my cv's i replaced the seals also....when i took them off last night i noticed that i somehow broke the driver side seal....so i was leakin tranny fluid...i had barely any fluid in there...lol....i am pickin up the seal today and some mtf from the dealer....this should fix the prob!!! thank you guys for the help!!!!
Mikey3000
09-24-2007 08:17 AM
