half shaft tranny cap keeps popping out of place. and spilling tranny fluid
* B A N N E D *
hey guys how is that cap supposed to be kept in place.
>>Im referring to the driver side half shaft.? that closes the gap around the half shaft where it connects to the tranny. It seemed to pop into place at first. but now it just snugs on and eventually just slide right off.. and i supposed to use some kind of adhesive.????
Re: half shaft tranny cap keeps popping out of place. and spilling tranny fluid (mustang5.slow)
I'm assuming you mean the CV shaft won't stay in your transmission. There is a small metal clip on the end of your CV shaft the locks it into place inside the tranny. You gotta push it in until it pops into place. There should be like 1/4inch gap inbetween the shaft and tranny when its locked in place.
* B A N N E D *
Re: half shaft tranny cap keeps popping out of place. and spilling tranny fluid (95vxtealhatch)
hey thaks for that answer...
but that not what i meant i edited my question for more detailed description.
I think that piece that you are asking about is just a dirt shield the sealing is done by the drive shaft seal
* B A N N E D *
Re: half shaft tranny cap keeps popping out of place. and spilling tranny fluid (instructor74)
well in my case that is what holds the oil in place.
am i missing a piece on my half shaft.???
Number 18 in this diagram is the oil seal
https://www.hondapartsdeals.co...M++12
Number 21 is the intermediate drive shaft on the small end of that there is a shield that you can't really see and that is the dust shield that I asked you about in your other post
https://www.hondapartsdeals.co...B++21
Modified by instructor74 at 12:52 PM 7/17/2007
* B A N N E D *
number 27... https://www.hondapartsdeals.co...B++21
it clamps ontho the the 18 on the other picture. https://www.hondapartsdeals.co...M++12
and the makes a seal thogether. but the number 27 keeps popping off the the rubber seal. why does it keep doint this.
Modified by mustang5.slow at 12:26 PM 7/17/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustang5.slow »</TD></TR><TR><TD CLASS="quote">number 27...https://www.hondapartsdeals.co...B++21
it clamps ontho the the 18 on the other picture.https://www.hondapartsdeals.co...M++12
and the makes a seal thogether. but the number 27 keeps popping off the the rubber seal. why does it keep doint this. </TD></TR></TABLE>
You need to either put a space in between the URL and your text or you have to put URL tags.
Nobody can click on what you posted.
* B A N N E D *
bump for desperate need of ideas.
Make sure you're putting the axle in right - if you put it in wrong (and a lot of people do) you knock that stupid clip right off and then it doesn't seal for ****.
Make sure ur putting it in straight as hell, not crooked. Then make sure it "clicks" in.
* B A N N E D *
Re: (Syndacate)
well i know exactly what clip you are referring to and i dont remember my half shaft having one but anyways is that clip supposed to keep the half shaft in on the fluid in>???
odidipissuoff
Transmission & Drivetrain
03-16-2010 06:45 PM
Nameless RB26
11-11-2002 11:38 AM
