the rear sags....
the rear sags....
I'm planning to do my suspension this weekend. Currently, my hatch is my DD. Over the weeks I've noticed that the rear is sagging, meaning the rear is significantly lower than the front. After replacing shocks and springs, will it solve this problem? Could it occur again?
Also, would 1.7" - 2" be a safe drop, without hitting the bottom of the car on bumps?
Two Piece
Re: the rear sags.... (meangreenEG)
just my guess....either the rear suspension is lower then the front that you know
2'' drop would be safe just be carefull when you go over railroads
but i would replace the suspension should fix the problem
or you could just raise the rear yourself its up to you
good luck
good luck
Arvid
07-12-2004 11:56 AM
