NEED HELP ON FOG LIGHTS!!!!!!
Yes i have a question..i did the write up exactly as told..but when i turned on the foglights wit the switch, only the passenger foglight turned on. i bought these foglights off ebay..and im guessing it could be that the two wires connecting from the inside of car to the outside of car is different. Interior Connector is Blue, and FogLight Connector is Red. could use some major help.. been having these foglights for about 4 months now and still cant get it to work properly.
this is why you dont go cheap on parts bro, especially electrical parts. First thing i'd do is take the entire harness apart and rewire it. I had to do to my 99-00 depo setup. I had so many problems with them.
What you can check for is ground, loose wiring and blown bulbs (my bulbs went out after 6months).
Re: NEED HELP ON FOG LIGHTS!!!!!! (Sarrow)
I just ran into the same problem for my 01 Civic. I did a fog light (ebay) conversion on my 95 Civic as well. The 95 went like a breeze, but the 01 was nothing but a headache. Unless you have the patience and knowledge it's better to get something good. I've found that were the wires meet the connectors they have poor connections at best. Check your wiring with a continuity tester. Make sure you're getting +12v at the lamp and finally a good ground. Have a blast, I know I did.
Re: NEED HELP ON FOG LIGHTS!!!!!! (RIZOBIZERT)
i recently got depo brand fogs for my 93 sedan.. the install was easy but getting the lights to funtion was a pain.. the harness was wired terribly and i had to run all new grounds, same problem my buddy had too.. other than that im happy with them, although i do expect bulbs going out soon
Re: NEED HELP ON FOG LIGHTS!!!!!! (92sihbk)
I had the same thing happend but it was actually the bulb that broke... must have been when it was shipped.
Re: NEED HELP ON FOG LIGHTS!!!!!! (Panda Eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Panda Eg6 »</TD></TR><TR><TD CLASS="quote">I had the same thing happend but it was actually the bulb that broke... must have been when it was shipped.</TD></TR></TABLE>
x2
x2
CHAMPwhteEK
04-03-2009 02:13 PM
