99 civic si pistons
Old 01-14-2008, 03:17 AM
danscompbiker90's Avatar
Default 99 civic si pistons
i was wondering if anyone has a diagram or knows how to change a piston on a 1999 civic si has a b16. any help would be great. thanks
Old 01-14-2008, 04:13 AM
HRD PKR
B16B_coupe's Avatar
Default Re: 99 civic si pistons (danscompbiker90)
I honestly dont think there is really any diagram on how to do it. Iam sure you can get a helms manual and it will help you some.
Old 01-14-2008, 05:18 AM
DCSportEJ1Civic's Avatar
changing pistons is somewhat of a big project. if youve never done something like this before and dont have a knowledgeable friend that will hep you for some free taco bell and a few beers i wouldnt suggest doing it yourself. but if you really want to try i say do a LOT of reading and research first.
Old 01-14-2008, 05:34 AM
crazyguy's Avatar
agreed to what the people said above.it is not an easy job and it is time consuming. u almost tear down the whole engine to do the job and while doing the jpistons swap. u might as well as replace all the gaskets and o rings, timing belt and water pump.
Old 01-14-2008, 06:29 AM
thanks for the suggestions and yea this would be a big project for me so im getting some help from one of my friends that knows his ****. he went to school for it.
Old 01-14-2008, 07:15 AM
Ek Forever y0!
Libertariat's Avatar
helms/Haynes
Whichever you can get your hands on. i really like my Haynes. However I've never seen a helms so I don't have a point of cross-reference.
Old 01-14-2008, 08:38 AM
Default Re: 99 civic si pistons (ek forever guy)
also should i change all of them or just replace the one thats shot?
Old 01-14-2008, 08:44 AM
HRD PKR
B16B_coupe's Avatar
How did the one go bad? hit with a valve? what happened? pics?
zerovandez's Avatar
why are you needing to change pistons? Are you upgrading? Or just OEM replacement? If it's for OEM I'd recommend just purchasing a shortblock instead. But if you really want to change out pistons then here's a link that should help you:
http://forums.evans-tuning.com...t=326
Old 01-14-2008, 08:48 AM
Default Re: 99 civic si pistons (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">How did the one go bad? hit with a valve? what happened? pics?</TD></TR></TABLE>
well im looking at buying a 2000 civic si and one of the pistons went bad i looked at the block and everything fine. i would just nned to change the piston and i was just wondering how long it would take
Old 01-14-2008, 08:50 AM
thanks for the link
Old 01-14-2008, 09:10 AM
HRD PKR
B16B_coupe's Avatar
It would take about a day to do
Old 01-14-2008, 09:41 AM
Man U FTW
Schister66's Avatar
Default Re: (zerovandez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">http://forums.evans-tuning.com...t=326</TD></TR></TABLE>
Follow that link. Its basically what you'll have to do except for the part about aftermarket pistons obviously.
Old 01-14-2008, 10:27 AM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danscompbiker90 &raquo;</TD></TR><TR><TD CLASS="quote">
well im looking at buying a 2000 civic si and one of the pistons went bad i looked at the block and everything fine. i would just nned to change the piston and i was just wondering how long it would take </TD></TR></TABLE>
Buy a short block. They're cheap...if one piston is bad, chances are there are other things wrong with the motor. What about cylinder wall wear? What if a sleeve is stretched? Is the piston broken? How is it bad? A piston going bad is usually caused by something violent.
Buy the short block. B16A short blocks can be had for like $600-800 now a days.
Old 01-14-2008, 11:17 AM
Ek Forever y0!
Default Re: 99 civic si pistons (B serious)
Amen, if you're buying a car with a messed up piston, and not just repairing the one you have: Buy a new shortblock.
Better YET!! Buy one with higher displacement, get a b18c/c5 block to go along with it. You'll be glad you did.
Old 01-14-2008, 12:10 PM
thisisntjared's Avatar
i am for a new short block too. if anything were to happen to my b16a2 i would gladly replace the long block with that of a b18c(whatever) and make some $ on the head.
Old 01-14-2008, 02:42 PM
Default Re: (thisisntjared)
as said before, read, read, and read some more. h-t is a great source of info, as well as, other websites, auto manuals, a honda dealership can print you a diagram of any part of your car you ask for, for free. also go to borders and check out some books on building engines. both general and honda specific. all the info you need is out there you just have to find it. anyone can do this themselves if theyre patient and take theyre time. and if it needs one just do them all. its already apart and if ones bad im willing to bet the other three took a beating as well.
Old 01-15-2008, 03:19 AM
Default Re: (DCSportEJ1Civic)
iight i was looking to just buy another longblock so i can just switch everything on to the new block.
Old 01-15-2008, 09:05 AM
B serious's Avatar
Default Re: (danscompbiker90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danscompbiker90 &raquo;</TD></TR><TR><TD CLASS="quote">iight i was looking to just buy another longblock so i can just switch everything on to the new block. </TD></TR></TABLE>
You should only have to switch the accesories and manifolds over.
Old 01-15-2008, 09:35 AM
Default Re: (B serious)
thats what i meant.
but does anyone no were i can find good deals on getting a long block? thanks
Old 01-15-2008, 09:39 AM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danscompbiker90 &raquo;</TD></TR><TR><TD CLASS="quote">thats what i meant.
but does anyone no were i can find good deals on getting a long block? thanks </TD></TR></TABLE>
Try Hmotorsonline.com. Or try n1concepts.com &lt;~~ they're a honda tech sponsor, i think...and they have really good prices.
Old 01-15-2008, 02:08 PM
ok thanks for all you guys help will hopwefully be working on this in a couple and have it on the rode in like a month
ProjectGSRHatch
01-22-2005 06:42 PM
hitvtecgetloud09
04-22-2004 02:10 AM
CiViC SiR
09-11-2002 12:01 PM
Quick Reply: 99 civic si pistons
