timing blet broke
timing blet broke
what all is prolly broke if the timing blet broke in a d16z6 motor some one said prolly bent push rods and some more **** is that true
Re: timing blet broke (07crf250)
your engine doesn't have any push rods, you have an overhead cam. You propably bent a couple of valves and possibly ruined a piston and a rod. GEt a new belt, set time, put the belt on and try turing it over by had with the sparkplugs out before you go and tear everything apart. maybe you got lucky.
later.
later.
Re: timing blet broke (boosted_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_EM1 »</TD></TR><TR><TD CLASS="quote">look for some bent valves </TD></TR></TABLE>
if you were going too fast you probably got bent valves, if you went slow enough...you might be able to get away with nothing bent or broken..get it checked
well i can buy the hole car for 225 dollars its a 92 civic 4 door with the d16z6 coil overs and some other stuff so sould i get and how much would a head cost me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 07crf250 »</TD></TR><TR><TD CLASS="quote">well i can buy the hole car for 225 dollars its a 92 civic 4 door with the d16z6 coil overs and some other stuff so sould i get and how much would a head cost me </TD></TR></TABLE>
damn thats hella cheap, if the motor was still good. the head is about 130 over here, but thats a good *** deal even for a 4-door civic.
EKB18BPR3
05-31-2004 02:34 PM
