question on d16y8 swap.
ok i just did a d16y7 to d16y8 swap, im useing p28ecu, now my question is by switching to the p28 which is obd1 which only use 1 o2senor, do i have to remove 1 o2senor or just plug both o2 sensor in?
Re: (z6hatchboy)
Yep, it'll run just fine. If you have the stock ECU you can run that too, then it'll just act like it's the stock non-vtec motor. If you're downgrading to OBD1 keep in mind you'll need the distributor as well, and you'll only need the 1 o2 sensor.
Modified by dubzz24 at 11:24 AM 1/16/2008
soo if i use my p28 ecu with the d16y8 motor. i would need the obd1 distributor? and i wanted to know that if your just useing 1 o2 sensor do i just leave it un plugged? or can i sill just plug it in soo there wont be a leak.
Re: (sky9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sky9 »</TD></TR><TR><TD CLASS="quote">soo if i use my p28 ecu with the d16y8 motor. i would need the obd1 distributor? and i wanted to know that if your just useing 1 o2 sensor do i just leave it un plugged? or can i sill just plug it in soo there wont be a leak.</TD></TR></TABLE>
You will only need to replace your dizzy if you are using an OBD1 ENGINE wiring harness.
If you are using an OBD1 ENGINE wiring harness yes, you will need a OBD1 Distributor, Namely one from a 1992-1995 Civic CX/DX/LX with a D15B7 or D15B8 motor, DO NOT PURCHASE A 1992-1995 EX or SI Dizzy, those are for the D16Z6 motor and will not line up to your Y8 head, I personally have a Y8 head on my car running a B8 Dizzy and it runs fine assuming you are using an OBD1 Wiring harness. If you are using an OBD2 Wiring harness that cam with the Y8 motor, Just plug everything in where it belongs, do not replace the dizzy, if your car will not start, remove your dizzy, spin it 180*, and try again, if still no start, you may need to get your P28 chipped for your Y8 *Which you should do anyways because the Y8 fuel maps are diffrent than a Z6*.
as far as the O2 goes
You can just use the O2 infront of the cat (assuming it is a 4 wire O2 and plugs into your wiring harness), and just clip the wires of the other one and leave it in there.
Johnny Racer
10
07-17-2015 12:46 AM
