eh hatch doesn't crank, main relay doesn't click, check engine doesn't come on.
Recently stripped my eh to nothing for a full color change put it back together now this is my problem doesn't crank, main relay doesn't click, check engine doesn't come on. any answers? I've been searching for awhile... btw i have a new main relay
thermostat ground
trans-chassis ground
the ECU controls those things, the ECU gets its ground from the thermostat, the thermostat ground path runs to the battery through the trans-chassis ground.
also check your underhood fuses.
Re: (Relic1)
i think i might need to take more paint off for the tranny ground to the frame iam definately convinced its paint blocking a ground ill try taking a little bit of paint off
Modified by ian. at 6:10 PM 1/14/2008
5poonhatch
08-19-2007 07:25 PM
