b16a oil temp and pressure
Old 01-14-2008, 03:17 PM
sohctodohc's Avatar
Default b16a oil temp and pressure
hey searched for some results on this and couldnt find a whole lot.
what is the normal temp your oil should be after your car is warmed up.
and would you rather see the oil temp in the oil pan(drain plug as sending unit) or flowing oil temp(oil block adapter)?
and what is the average pressure WOT? idling? and cruising???
by the way this is a stock obd1 b16a
ok so got the gauges in the center console and at cold idle, idle then wot it goes as follows:
80psi
22psi
80psi
does that sound right?
thanks for the help
Modified by sohctodohc at 7:20 PM 1/14/2008
Modified by sohctodohc at 7:47 PM 1/21/2008
Old 01-14-2008, 04:19 PM
sohctodohc's Avatar
Default Re: b16a oil temp and pressure (sohctodohc)
ttt
Old 01-14-2008, 05:31 PM
sohctodohc's Avatar
**** is movin fast tonight
Old 01-15-2008, 09:34 AM
sohctodohc's Avatar
so there hasnt been anyone with oil pressure and temp gauges???? hmm weird
Old 01-21-2008, 06:52 PM
sohctodohc's Avatar
ttt
Excusetobooost
06-09-2020 01:19 PM
TeamSeanFTW
03-15-2011 06:41 PM
sohctodohc
01-22-2008 04:13 PM
TurboCX
08-03-2003 06:33 PM
Driven
01-04-2002 01:35 PM
Quick Reply: b16a oil temp and pressure
