Need Help: 96 Civic hatcback - Trunk Doesn't stay close
Hello all, I just picked up ANOTHER Honda today... a 1996 Honda Civic CX hatchback and for some reason, the rear trunk door wont stay shut! I slam it down all the way and it bounces. I was looking at the latches and I don't know what to do nor look for. I tried playing with the "trunk open" lever near the driver's seat and I don't know what to do.
PS: If anyone has one for sale let me know. Thanks!
ANY HELP WILL BE APPRECIATED.
Check if the latch is sticking. It sounds like it is getting stuck in the open position and when you shut the hatch it just bounces back because the latch is not trying to grab.
Re: (Hittnthebz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hittnthebz »</TD></TR><TR><TD CLASS="quote">Check if the latch is sticking. It sounds like it is getting stuck in the open position and when you shut the hatch it just bounces back because the latch is not trying to grab.</TD></TR></TABLE>
+1 the same thing happened to my hood
Re: (Hittnthebz)
The latch isn't sticking. The spring is functioning and all, the latch just doesn't "lock" . ANyone else? BTW, thank you for the replies.
H-T White Ops
Wish I could help. My hood does the same thing and I have to stick my finger down there and move the tab back to where it's supposed to be. I'll probably just have to replace the latch instead.
Re: (NOFX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">Wish I could help. My hood does the same thing and I have to stick my finger down there and move the tab back to where it's supposed to be. I'll probably just have to replace the latch instead. </TD></TR></TABLE> Ouch.
Re: Need Help: 96 Civic hatcback - Trunk Doesn't stay close (Agent_EM1)
https://honda-tech.com/zerothread/1234314
sounds like the same issue on a different part of the car. give it a try.
i have a STOCK flat black BRAND NEW OEM ek hatch (just the HATCH BARE SHELL) only. you will need to transfer glasses, wires,... to the new one.
$100 shipped to you.
im in texas btw
im in texas btw
H-T White Ops
Re: (Agent_EM1)
Oh, and as far as my hood, I've replaced the cable before. It's not that. For some reason it's always been kind of stiff compared to what it should be. It's almost like the two springs within the latch are backwards. The one that should be tighter is looser and visa versa.
When I pull the tab inside the car, the latch doesn't spring back to it's original position.
You should be able to (at most) fix this by replacing the latches. You won't need a full hatch.
go inside the trunk with a flashlight, and ask someone to close it couple of times, you will find the problem right a way.
but i also think its the latch, might be too greasy and not allowing the latch to lock down.
The latch is probably already closed. With a screw driver, try to rotate the striker in the latch while someone hits the release in the car. It should flip open and you should be able to close the hatch.
Re: (Bakeoff)
I appreciate the replies from everyone. I will try all of the above when I get home and i'm going to try to take some pics of my latch. As far as the guy selling his, $100? There's some on ebay for $30 shipped for what I need. If I can't fix it I may just buy a new one.
Re: (Hittnthebz)
I don't know what I did. I stuck a flat head inside the latch mechanism and kept poking things, then I slammed my trunk and voila, it latched.
gbadude
10-16-2004 07:09 AM
Honda_hatch 96
05-25-2004 11:55 PM
