Battery gets REAL hot when both cables attached...
Old 06-14-2011, 11:12 AM
bandit67's Avatar
Default Battery gets REAL hot when both cables attached...
Guys, just drug home another challenge. Bought a 95 coupe ,non VTEC that has been sitting up for a LONG time. Previous owner said field mice had chewed on the wiring harness somewhere and now when cables attached the battery gets hot. Am headed out to trouble shoot in a bit and was wondering best way to trouble shoot. First glance underhood shows no obvious visual problems.
What fuse or fuses can I pull to split the electrical pathways. Can you separate, underhood, interior, trunk to help narrow down where the problem may be. I think the underhood fuse block would be the key place to start......thanks.....
Old 06-14-2011, 11:16 AM
Former User's Avatar
Default Re: Battery gets REAL hot when both cables attached...
The cables get hot with the key off, right? If so, remove each hood fuse one at a time to see which unplugged fuse prevents the problem.
Old 06-14-2011, 11:53 AM
virgineg6's Avatar
Inspect ervey inch of wiring, then worry about seperating systems
Old 06-14-2011, 09:57 PM
bandit67's Avatar
Finally found two problems, brake light switch pad had dried up and fallen out, and a critter had chewed into one side of the brake lights and some wires were shorted together. New stop pad and spliced leads back together has solved cooking battery......thanks..
EusebioSam19
08-12-2012 01:29 PM
K i l l a B e e.
10-12-2006 10:30 PM
Civic138
01-04-2005 05:59 AM
idteg
11-01-2004 10:46 AM
Quick Reply: Battery gets REAL hot when both cables attached...
