No spark. Out of ideas
Well long story short Im getting no spark. I've tested just about everything at this point.
I've got new spark plugs
3 dizzys to test on that are known good
Tested the grounds
Continuity on igniter wire all the way to igniter
It seems that the only thing I've seen wrong is no power on the actual coil. But seeing as that is a problem on all 3 dizzys what could cause that?
Tested the grounds
The Grumpiest
Re: No spark. Out of ideas
Is this the same continuing issue as in this thread?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/car-wont-start-vafc-flickering-runs-like-shit-2895533/
In that post you stated that you got the ECU wet.
This is a whole new issue..I thought the Ecu had gotten wet but it was just the starter that had gotten wet and shorted out.
It could be your ECU or your main relay. If the coil isnt getting any power thats your problem. Check continuity between the power source and the wire for the coil
No it's LS/v now. And I'll swap out the Ecu today but I'm not sure if it would be the main relay since it clicks like normal and I'm getting fuel pressure
What car?
Any CeL codes?
Does the Blk/Yel wire attached to the coil and igniter unit have battery voltage with the key in ON(II)?
Does the Yel/Grn wire running between the igniter unit and ECU have a short or open?
Any CeL codes?
It's an Em1. Stock harness. Motor is ls/v. There is continuity between the igniter and the Ecu. Yes the yellow and black has power with key on. No cels
I've swapped the ECU with a buddy and still nothing. Tested the ignition switch and it seems to be good. When I test the dizzy with it plugged in..no + at the coil but i'll get + all around the coil..going in and coming out. But shouldnt the - side of the coil be grounded instead of hot? Makes sense to me
Pulled out the whole harness to do some continuity checks, check for shorts and ohm it out. Everything seems fine so far..which leads me to believe it could be the ecu (even tho i've tried two p28s).
Battery is good (brand new)->Ignition switch good->Main relay good (tested it and the fuel pump works)-> Tried 2 different P28s which seem fine -> 3 different dizzys -> Spark Plug wires ohm out fine-> New Spark Plugs.
Grounds seem fine but I might not be getting the pulsing ground from the ecu to create spark.
Other than changing out the ecu again im at a complete loss
winquest1000
06-30-2014 10:10 AM
GSR_EJ2
16
09-03-2009 07:02 AM
SoHc94
11-19-2006 02:51 PM
