obd1 gsr swap in to Ek Question ??
i have a question for you guys, im sure someone can help me out!!
has anyone done this swap before. On the ek (1996 dx) is the a jumper harness for the engine harness?? do I need to use the entire harness off of the integra and put it into the EK?? like from the computer on.. I hope I dont have to...or... what do I need to make it plug in play.. Thanks for all the help
Re: obd1 gsr swap in to Ek Question ??
so your trying to do a b series swap on a ek huh ??? well your gonna need a obd2 motor with engine harness because on the ek .... the engine harness goes all the way to the ecu. not like the eg when they have a 3 plug connector before the ecu. also you will need b16 motor mounts. only the 3 main mounts.
your looking into putting a obd1 motor in so you would have to put a obd2 dizzy & rewiring a few wires but you will need obd2 gsr ecu because it's a ek
This has been covered a million times before...
Use your 96 EK engine harness and modify it to fit the GSR engine. You can NOT use an integra engine harness in an EK chassis.
Ok here's what you do extend some wires if need be but get an after market intake manifold (skunk 2) so the wiring would be more similar to that of a civics cuz the Gsr uses butterfly gaynes valves on the im so all you would have to do is wire vtec if your ek doesn't already have it then get an obd2-obd1 jumper harness for the obd1 ecu then get a p28 lol that's how I'd do it
Technical Hero
VTEC WIRING
For the wiring use your harness and buy a VTEC subharness to run wiring for VTEC/knock/IAB's.
IDLE AIR CONTROL VALVE
You'll also need to convert your idle air control valve plug to two wire (see picture below):
DISTRIBUTOR
No you can use all the OBD1 components you can use a distributor jumper harness:
Alternator
For the alternator its possible you can do this:
or
INJECTORS
For the injectors this and they'll plug right in:
INTAKE AIR TEMP SENSOR
For the intake air temp sensor you'll need to do something like this into your intake:
ECU
If you end up staying OBD2 you'll need an OBD2A P72 ECU. If you go this route you'll also need an O2 extension harness to extend your secondary O2. Also you'll need to bypass the CKF sensor (http://www.ff-squad.com/technet/ckftrick.htm).
If you go OBD1 (RECOMMENDED) you'll want an OBD1 P72 ECU or chipped P28 this will delete the secondary O2 and CKF sensor and make your life a bit easier. You'll want an OBD2-1 ECU adapter in this case.
DISTRIBUTOR
Alternator
or
INJECTORS
ECU
