B16A2 Swap Question
B16A2 Swap Question
im currently in the process of getting a b16a2 from a 00' EM1 into my 94' cx hatch and had a quick question on when i swap it in. since im going to BAR it i know i need the P2T Ecu, but would it make the swap alot easier if i got the EM1 engine harness? or do i even need it?
any help would be appreciated
Re: B16A2 Swap Question
The EM1 engine harness will have the right ECU plugs, and the ones for the sensors. So it might be easier. But your really going to have a OBD2 setup in a OBD1 car? Idk how that even works honestly.
You will need to convert fully to OBD2 (obd2 CA catalytic converter, obd2 style charcoal canister, fuel tank pressure sensor, etc.) Also, in so Cal, you can NOT use a jumper harness through the referree. You will have to hard-wire in the conversion at the ECU (a real pain in the A$$). You are better off installing an OBD1 longblock and BAR'ing as a Del Sol VTEC swap
I'd recommend selling that engine since you already bought it and either locating a b16a3 del sol B16, or even better a 94-95 GSR engine.
You can't use an EK engine harness in a 92-95 civic. It is completely different, plugs are in different areas, wires at different plugs, and the dash wiring is integrated at the EK harness plugs where it isn't on the EG. You have to use an EG or DC2 engine harness.
i did some searching in the archives and found a thread that someone else has done this swap before, but didn't bar it because they lived in chicago. this is what someone said they needed:
99-00 Civic SI B16a2 in a 95 Civic EG???? (SOHC_2_DOHC)
i just did the swap the other day. if you have a 99-00 b16 this is what you need.
1.96-01 gsr or ls harness
2.obd-1 gsr(p72) ecu, b16(p30), or a chipped p28
3.complete swap from si including axles, shift linkage.
4.94-01 rear L bracket or t bracket or rear tranny mount.
im curious if id be able to pass bar with a p30 which i assume is obd1 and i dont know if that'll work with my motor.
well my question hasnt really been answered at all. my question was would i be able to bar my car with this motor and all the appropriate equip on it. not to just be able to swap the motor in my car...
Its too much of a hassle to bar a obd2 engine in a obd1 car. Your just better of running the motor with the steps you suggested above. The p30 will not work to have the car bar'd because its an odb1 ecu making an obd2 engine run. According to the state ref if the motor is an odb2 then everything in your car must be obd2. As far as a Del Sol Vtec it can use this 99-00 Si motor as a replacement motor if its original b16a3 motor is blown because the Del Sol Vtec is originally equipped with a b16 motor in the United States legitimately. Whereas the 92-95 civic hatch or any 92-95 civic in that matter was never offered the b16 as an option so this is the reason why everything has to balance with the year of the motor.
It doesn't have to be a difficult swap but, even without the wiring hassle you'd have to go through for the OBD2 conversion, it is hard to get the state referee to BAR anything. There's so much paperwork and bureaucracy. I used to live in so cal and I would always just get a crooked smog somewhere in order to appease the dmv. Just avoid smog checkpoints and don't rip on your car on freeway on ramps where they hide the emissions sensors.
Ek Forever y0!
Hint:
The Grumpiest
the whole thing. still doesnt let me know if i'll be able to bar this engine in my car. all that states is info about the ref and bull. all i need is a yes or no answer (which apparently noone can provide) so i can close this damn thread.
Ek Forever y0!
You have an OBD2 engine, to bar it your whole car must be OBD2
You can't do it.
DAM...got tired of reading all the crap sorry to say but some ppl dont know there **** i just bared this same motor in to a 94 ej1 so if you want to bar it hit me up i can get it done for you i have all the parts to bar any b16 into any 92-95 civic jdm or usdm and ive also done a jdm B16 and im about to bar one more for some guy
LMFAO whent back and read some of the post and dam thud: dam ppl dont know **** lol you run it as a del sol B16 and YES you CAN ill put money on it i just did one and have done a jdm B16a and are about to bar some guys JDM OBD2 b16 in his eg......
wtf you can do it, it's just going to be ALOT of money..didn't anyone hear him he just got the motor...i'm sure he doesn't want to sell it anyways so soon....
but being realistic maybe sell and aim for a gsr motor pros easier to bar,swap, and more power for your car. but up to you really what you wanna do.
