Headgasket... Maybe?
I'm having trouble with my 99 coupe. The other day she started to overheat so I pulled over and let her cool down. Once I make it home I think thermostat, so I pull it and it seems to fix the problem... But now I need getting air in my coolant system. It keeps pushing coolant from the rad to the overflow tank. I bleed the system and keeps happening. Now I'm thinking headgasket, but I don't have the normal problems, no oil in water, no smoke, nothing.... Any ideas
Re: Headgasket... Maybe?
Bleeding the cooling system may take 20-30 minutes:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below (hint: the bleed bolt is located where the upper radiator hose connects to the engine):
My sister's 98 cx had the same issue.. The overflow tank keeps getting full. The oil wasn't showing any signs of water n oil mixture. I took it in to my mechanic, they did a leak down test and conclude to headgasket.
grimview
07-22-2013 03:32 PM
snibbor
10
06-07-2011 09:40 AM
jxhxb
06-28-2010 05:16 PM
blumpfish
04-09-2009 11:32 PM
ekcivic9
03-07-2006 09:13 PM
