1996 Civic EX - Headlights dull, replace bulb or whole unit?
So my 1996 Civic is obviously climbing up there in age. I don't think the headlights have ever been changed, but I do think they are not very bright anymore. Maybe technology has changed I don't really know but compared to other cars it seems like I don't put out much light.
The outside headlights are definitely yellowed and fogged up. Using the meguiars plastix stuff helps a little after you use it, but it's obviously short term.
So I was wondering... should I just try replacing the bulbs or the whole headlight unit? I'm not sure what just bulbs cost but the whole units are like 100 bucks for a pair. A bit more than I want to spend, but I don't really know if changing the headlights will help for sure. Should I expect a noticeable improvement by upgrading these 15 year old lamp lights?
Re: 1996 Civic EX - Headlights dull, replace bulb or whole unit?
Plast-x is NOT short term if done correctly. If the dulling of your lights is due to hazing/oxidation on the lenses, replacing just the bulbs will not help.
Do you have a drill?
The 3m headlight restore kit works great!! It's the only one I will use.
Do that, and then throw some better halogen bulbs in it.
Yeah def clean the lenses or buy new ones... If not, check your grounds. My 94's we're dull and I re did both sides grounds+changed the bulbs and it was literally night and day, no pun intended.
You can do one of these two:
http://www.youtube.com/watch?v=ggO4G0iEcnk
or
http://www.ebay.com/sch/i.html?_nkw=....c0.m270.l1313
I got mine for $70 from ebay, but did not insatl them yet.
or
Don't waste your money on those ebay peices of ****. I had them, now they just sit in the garage.
Oh yea, the tabs break really easy so whatch out for that.
Also, if you go ebay... buy a bottle of silicone sealant too. You'll need to re-seal them upon arrival.
what i do is 600 Grit 800 Grit 1000 grit 1500 Grit 2000Grit some car polish Meguiars mirror glaze fine cut cleaner than plast X and than i just use a little turtle wax and the headlights on all my cars are brand new looking even did it on my friends 350Z Supercharged and when you look at them from a distance it looks like it has no plastic lens just internals
yeah i also use a buffer with all of this when im putting the stuff on but hwen i wax it i just use it by hand with the little pad they give u
I bought them already from ebay.
What kind of silicone is good to get and also what kind of polish to put on them to prevent the plastic from dulling and cracking?
Thanks in advance to whom will answer!
Drive safely!
