Random blue sensor with no plug on back of HX block?
Old 09-18-2011, 07:31 AM
nytosc's Avatar
Location: New York in the summer, South Carolina in the winter
Default Random blue sensor with no plug on back of HX block?
While changing the oil on my civic HX I noticed a sensor that had no plug in it on the back of the block. I looked all over but did not see a plug for it. Anyone know if this is normal? It looks like a knock sensor and is blue.
Old 09-18-2011, 07:34 AM
Former User's Avatar
Default Re: Random blue sensor with no plug on back of HX block?
Post a picture.
Old 09-18-2011, 08:30 AM
virgineg6's Avatar
Does your oil pressure indication light come on, on the dash when you turn the key to II?
Old 09-18-2011, 09:38 AM
Technical Hero
HondaPartsHero's Avatar
Is yours a 5 speed or CVT? Look like this:
Or this
Old 09-18-2011, 10:55 AM
nytosc's Avatar
Mine is 5 speed. It is not the oil pressure sending unit- no CELs or codes.
Thank you all for responses they are much appreciated
Old 09-18-2011, 11:06 AM
92lxsleeper's Avatar
is the engine in it the orignal engine? sounds like a knock sensor
Old 09-18-2011, 05:06 PM
nytosc's Avatar
Yes original engine car has never been modified or anything of that nature- I really think its a knock sensor but am confused why there is no wiring for it? The plug also appears to be quite clean which makes me believe the plug wiring fell off recently but it is no where to be found...
Old 09-18-2011, 05:12 PM
An unplugged knock sensor would throw a CEL code. Does the CEL work? What ECU do you have?
Old 09-18-2011, 05:34 PM
Technical Hero
Have you had the car since new? Only the CVT's had the knock sensor according to Majestic website.
Old 09-18-2011, 05:37 PM
I think you are correct.
Old 09-18-2011, 06:14 PM
Technical Hero
Just wondering if that is a knock sensor if someone swapped blocks (or engines) out at some point in time in the car's history
Old 09-18-2011, 09:44 PM
Texas4door's Avatar
If the block was swapped, then the VIN riveted to the block wouldn't match the car
Randyb18
08-10-2015 09:14 AM
Japankid
Welding / Fabrication
04-09-2009 12:35 PM
burntheblobs
06-28-2007 04:21 PM
turbo gsr
04-26-2006 03:00 PM
crashtest Sonny
08-26-2003 03:11 PM
Quick Reply: Random blue sensor with no plug on back of HX block?
