passing smog with JDM D15B
I'm having trouble with passing smog because the shop is saying that I'm running the wrong ECU. The JDM D15B was installed professionally by a shop and apparently they did some sort of "ecu conversion" and VTEC is wired up with no check engine light. I can't get ahold of the shop so thats why im coming here.
What I've gathered is that the D15B does not have a pressure switch? That's what threw the mechanic off and made him abort the smog test. What exactly do I need to do in order for it to pass so I can sell it?
Located in California by the way.
Re: passing smog with JDM D15B
what engine harness are you using? and what ecu are you running?
if you are using the p28, which will look for vtec pressure then who ever wired it up rigged the wires to the solenoid.> cut off the pressure switch plug and secure wire and tuck it away. or find a usdm vtec base with the pressure switch. smog tech abort cuz you didnt pass visual. or you just throw in a dx ecu. i passed my del sol sohc vtec with a dx ecu.
i too am in california. i got away with passing a d16y7 in a 98 ex equipped with a d16y8.
This is how it looks. This is an old picture when the wiring accidentally came undone. There is now one single wire coming from the ECU which plugs into the solenoid. Upon inspection I found out that I am running a P05 ECU which apparently is the stock CX ECU. Apparently it's been "converted" or something, does this sound right? Would I need a whole different wiring harness to run a P28 ECU?
#1 Super Guy
Yes you can convert a stock P05 to VTEC just like a P28. I'm running a B18C with one.
What you need to do to pass this visual, is get the correct plug for this socket and plug it in. Then run the wires down into some split-loom so it looks legit. If your not throwing a code, the tech shouldn't trace them all the way back to the ECU. If you are worried about them tracing them, then simply run them all the way to the ECU (even though your ECU isn't looking for them).
I don't quite understand why your JDM motor has a vtec pressure switch though. I thought they didn't have this feature over there. Perhaps that's only B-series.
Wow, you paid a shop to do it legit and they seem to have "missed" a few steps. Leaving the switch unplug, with a USDM solenoid. I would go back and have them wired that bitch to the ecu and make sure you have the correct ecu. Which is a stock P28. Unacceptable.
P.S. - You're missing a dizzy bolt. Just barely caught it.
I actually bought the car about a month after the swap had been done, so I didn't pay anything. I think I'm just gonna try to make it look legit and take it to a different smog station. I've never had a CEL since I've owned the car so it should be good to go. It's just kinda surprising to me that this shop (which has a pretty high reputation of doing JDM swaps) would half *** this job so much. And thanks for mentioning the dizzy bolt, I noticed that a long time ago and keep forgetting to fix it haha
just use a obd1 civic si or ex harness and it should be plug n play having all the harness plug you need, to my knowledge most or all eg chasis comes pre wire vtec already, using a p28 and the harness and you'll be good to go legit. but not really sure they pass you, yours is a 1.5L and ex/si are 1.6L so you might have to get it state reff bard.
im not postive but i have a JDM D15b as well and i had some issues that ended up just being the o2 sensor but i remember doing a lot of research having to do with OBD1 and OBD2 cars. my D15b is OBD2 in an OBD2 car (post 95 i think) your car which is older might be OBD1 with an OBD2 motor. like i said not positive but just figured id put in my little bit of knowledge
dohctor_B
10-01-2005 05:37 PM
SuperDuude
10-26-2004 11:26 PM
