B16a temp sensor broke off
Old 09-17-2011, 04:05 PM
89REXTEC's Avatar
Default B16a temp sensor broke off
Can the sensor be removed without damaging anything? I need to know.
Old 09-17-2011, 04:48 PM
motegicivic's Avatar
Wow, if memory serves me right this is not the best places to work (tight). If you use an easy out it will be hard to work in the area, it needs to be drilled in the center and dead straight too.
Is the car running funny, any codes?
Old 09-17-2011, 08:02 PM
89REXTEC's Avatar
Default Re: Engine Coolant Temp Sensor broke off
The check engine light did come on and I'm pretty sure VTEC isn't engaging either.
Old 09-18-2011, 07:21 AM
Former User's Avatar
Default Re: B16a temp sensor broke off
There are three temp sensors on your engine:
On the thermostat housing: The 2-wire temp switch
Under the distributor: The 1-wire temp sender unit for the cluster and the 2-wire temp sensor for the ECU
Which one are you talking about?
Old 09-18-2011, 10:15 AM
89REXTEC's Avatar
The one i broke is the two wire sensor for the ECU I believe. It's under the VTEC Solenoid and plugs right into the water jacket.
Old 09-18-2011, 10:19 AM
Post a picture of the broken sensor.
Old 09-18-2011, 11:11 AM
92lxsleeper's Avatar
if its the one that plugs into the thermostat housing just get another one.
http://www.hondaautomotiveparts.com/...TAT+%28DOHC%29
you need part 5 - $11.20
and part 11 - $35.50
might as well get a new thermostat and gasket while ur in there. part 3 - $15.77
Old 09-18-2011, 11:13 AM
if its not that one , u either need part 10 or 12. and youre better off relocating it, instead of easy outting it out of the cylinder head. aluminum is weak.
Old 09-18-2011, 11:20 AM
Lesvtec's Avatar
How anymore mpg do you want?
Old 09-18-2011, 05:09 PM
That is not the one that broke, it is the one that lets the computer know the coolant temp.
710dabber
11-05-2015 12:36 PM
joestud
09-14-2013 01:58 PM
jemo1
06-05-2013 05:55 PM
prelude-bb3
07-25-2004 11:42 PM
Adam_F123
03-18-2004 05:18 AM
Quick Reply: B16a temp sensor broke off
