Anyone ever done a zc swap in an eg sedan?
Old 09-18-2011, 05:54 AM
chope045's Avatar
Default Anyone ever done a zc swap in an eg sedan?
has anyone ever done a zc swap in a eg sedan
Old 09-18-2011, 06:26 AM
Former User's Avatar
Default Re: Anyone ever done a zc swap in an eg sedan?
Please place your simple tech questions directly into the thread title -- edited.
Old 09-18-2011, 06:45 AM
EGCIVICKING95's Avatar
Im lookin into doin this swap, probably not til late nov. early dec tho. Would deffinately make for and interestin swap, plus the D16Z6 swap that came in my car is pissin me off.
Old 09-18-2011, 06:59 AM
JDM-sol 89's Avatar
I'm sure plenty of people have done this swap in the past. It's literally just an ordinary d series but with with a dual cam head.
Old 09-18-2011, 08:35 AM
virgineg6's Avatar
Not all ZC's are dual cam there are single cam ZC's. Which one are you gonna swap in?
Old 09-18-2011, 11:07 AM
92lxsleeper's Avatar
either way they drop right in. you can get a full dohc zc obd1 for about $800 plus shipping, including transmission. comes with everything you need including axles, jack shaft, and ecu.
Old 09-18-2011, 03:05 PM
chope045's Avatar
im not sure yet ive just started thinking about junking my mini me and what to do something a lil different then everybody else
Old 09-18-2011, 03:07 PM
chope045's Avatar
92lxsleeper where did you find that information at everywhere ive looked their going for 1000 just the motor
Old 09-18-2011, 03:41 PM
miked123's Avatar
if your just gonna junk the motor, il take it
Old 09-18-2011, 04:52 PM
the dual cam ZC im lookin at is like $650-$700 just the motor tho. If your in new jeresy hit up JDM Engine depot. Ive heard nothin but great things bout them.
http://www.jdmenginedepot.com
Old 09-19-2011, 03:51 AM
chope045's Avatar
miked123 you dont want this motor it has givin me nothing but problems
but EGCIVICKING95 thanks for the link im sure they can sent me one down to fl
Old 09-19-2011, 08:54 AM
your welcome. Im sure if you if contact them they may ship it. miked123 if you want when i tear out my D16Z6 ill gladly sell in to you. the damn thing will be lucky if i dont blow it up.
Old 09-19-2011, 06:29 PM
keep an eye on ebay they pop up all the time. you can even spend a little more and get factory LSD. but you can always use a normal D series transmission as long as you use a 92-00 d series flywheel and clutch.
Old 09-19-2011, 06:30 PM
http://cgi.ebay.com/ebaymotors/92-95...item588fc48b66
there u go, everything but the ecu for under $1000. shipping isn't too bad either depending on where you live.
Old 09-20-2011, 07:07 AM
chope045's Avatar
well now all i have to do is save up
Old 09-22-2011, 01:26 AM
Alphacrewrocker's Avatar
i say go for the single zc instead, i had a 92 hatch with a zc n its was hot, eat up duals all day beside the b18c1 they hot but you can hang with em, the dual zc and single are about the same horses just the single is light.
Old 09-23-2011, 11:04 AM
chope045's Avatar
i like the single cam idea it all really depends on how much they cost
Old 09-24-2011, 07:30 AM
chope045's Avatar
ive been reading on other forms and some people have been talking about a sohc vtec zc is this a real motor or just another mini me
Old 09-24-2011, 09:32 AM
its a real motor. its basically a d15b with higher compression i believe? someone correct me if im wrong.
Old 09-24-2011, 03:01 PM
chope045's Avatar
anyone know where to get one ive looked and all i can find is dohc and sohc zc
Old 09-24-2011, 09:05 PM
fonkernuckle's Avatar
I have a sohc zc in my ef si hatch with the si trans same ecu and it has plenty of umpff sohc zc's are not as abundant as they were years back on eb ay but dohc are.
I have installed an dohc zc in an eg sedan and its plug and plug just remember to get an obd-1 zc or if obd-0 then you will need the zc obd-1 intake and zc obd-1 dizz. I used a obd-1 pr4 to run it but the appropriate one to use the p29.
I am just putting the finishing touches on another dohc zc in my eg hatch (came with a bad water pump and did not know this until I had installed the motor) pm if you do get one and have questions.
Tylooch
03-03-2012 03:21 PM
90 DX Driver
04-04-2009 11:31 AM
Rainville
12-13-2004 01:55 PM
Toxic H
05-08-2003 08:04 AM
Quick Reply: Anyone ever done a zc swap in an eg sedan?
