97 DX radiator hose removal tips, anyone?!
So I'm getting everything disconnected and removed since my new radiator should be there tomorrow or Wednesday... First time ever doing a radiator but seems pretty self explanatory and was the first 30 minutes. Drained the coolant, got both big (upper/lower) hoses disconnected, moved the reservoir box, moved the ac line for access to the two little lower hoses and moved the clamps and the hoses will not budge. Prying with a screwdriver, pulling with all my might, no budge. Any tips? I'm afraid if I cut them, They'll be stuck on the nipples, especially on the other side where they run over the trans, etc. Here's a diagram, they are 10,11. Thanks again for any help.
Re: 97 DX radiator hose removal tips, anyone?!
Think of it as a chinese finger trap. The more you yank on it the tighter it will get. If you are going to replace the radiator, you may as well cut them off with a sharp razor and spend another $10 on some new hoses.
Yeah I was just now contemplating that... I have sharp razors at work that would just splice them down the side and I already have to go to Honda to pick up a cam seal for my hatch.. Do you know what those hoses go to? I suppose I could just point at them on their parts diagram like I always do, lol.
Yes, just have them look them up for you, if they are old might as well replace them.
As for getting off the old ones, you might want to try twisting and pulling twist a little and pull and keep doing it until it comes off, or just cut them off.
I agree that replacing the hoses is the best idea. With that said, put on a pair of gloves, grab the hose near the nipple, and apply a forceful side-to-side/back-and-forth movement on the hose. This will generally break it loose. If limited space is the problem, it may be easier to first remove the hoses from the transmission side and then remove the radiator. With the radiator out, you should more easily be able to get the hoses off.
sometimes i try breaking the seal and take a flat screwdriver around the nipple and hose working it around the opening to break it free a lil. then as they said tug side to side and twist it. it will eventually break loose u can also use channel locks to grab it just be careful not to tear it. if u do just replace the hose. autozone sells a grease that u can put around the nipples so it does not stick like this next time.
Technical Hero
I just replaced the radiator on my wife's car. I replaced both radiator hoses and those trans hoses. 2 ft of the trans line at Advance was $4. Just make sure you get the exact diameter and get trans line not fuel/coolant. I got the radiator hoses at Honda, they were very inexpensive (maybe $18 for both) and were OEM fit.
go to ace hardware and take a 10mm bolt with u so u get the right pitch and size bolt. they have stainless bolts that wont rust and last longer.
to remove the hose, i use channel locks and twist them back and forth. sometimes people will put rtv silicone on the radiator tubes if they leak and can't get a new hose to seal, or it its cracked and it may make the hose impossiible to remove. if channel locks dont twist it, dont cut it near the neck with a knife, you may push through and puncture the neck. use a heat gun to heat the hose up and twist again. it'll come off
lucasbkellner
10
11-15-2004 04:13 PM
