97 hatch shell - How convert d16z6 to OBD II? Can 92-95 si tranny be used?
ok im picking up a 97 shell today with a 2000 front end. quarters are rusted a bit, not as bad as my 92 was.
quesiton is, what is needed to convert a d16z6 to OBD II, and can a 92-95 si tranny be used in the 97 as well?
i can't use a jumper harness for obd2-1 because of emissions, basically obd-2 cars just use a code reader. so a d16z6 is cheaper at the junkyard than a d16y8 so if it can be converted its all good.
Re: picking up a 97 hatch shell today
im pretty sure you need to convert it to a OBD1 also what junkyard looks at engine codes and why would you buy an engine from a junkyard?? unless youre doing a full rebuild than its really not worth it
they dont check engine codes here. they just plug the scanner into the obd2 port. so i would have to convert the obd1 engine to obd2
because they are warrantied and will get me around for the time being. i want to build the car back to stock, maybe a little more. i have health problems and pay doctors out of pocket, so i cant continue to drive my truck at 10mpg for another year or so.
CGS
10-26-2005 07:24 PM
dabigfunkymunky
08-11-2001 11:02 AM
