need help with si guage cluster speedo not working?
so i have a 1999 si my my speedo is not working but my tach and everything else works, i herd of something about the film or something not working in the gauge and trying to figure out becuz my v-tech is not cracking n the mechanic said it wouldnt crack until the speedo works can anyone give me any info ?
Re: need help with si guage cluster speedo not working?
1. Find any cluster from and EK
2. Install this cluster
3. See if Speedo works
4. If it works you need a new cluster
If it does not work put your old cluster back in and check the wiring
Does the CEL work?
You may want to read this thread:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/speedo-jumps-around-vss-plug-speedo-screws-speedo-circuit-board-2333600/
So I checked the closer and new speed sensor but still my Speedo isn't reading anything , all my wires are in tact , , and the only check engine light I got was for my oxygen sensor and one called heater circuit bank , but I can figure y my vtech isn't turning on I'm running an itr with a si ecu does that affect anything
Itd had a different ecu in there made it freak out when it hit 5k rmp, n when I put the so one in it let's it pass it
