civic 98 lx not start...
I follow the guide for make the ignition system tuneup, only change the cap and rotor with spark plug wires, yesterday I did injector cleaning, today started the car and suddenly turn off and check everything and good, I advise?
Re: civic 98 lx not start...
yeah, https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-96-00-honda-civic-tune-up-fuel-filter-2872418/ i follow this guide and everything is ok, mmm i go to change I will leave it as it was
mmm, remove the spark plugs and noticed they were wet with fuel, that happened when you change the rotor and rotor cap, cleaned and re-setting, change the rotor and cap used by the original, I'm waiting a few minutes to dry , be right back ...
do not quite understand here.
4) While firmly grounding the threads of the spark plug against a clean metallic area of the valve cover, have a buddy crank the engine. If you are concerned about getting shocked, you can wear a rubber glove on the hand holding the spark plug, though this is really unnecessary if you take care to keep fingers or other body parts away from the spark plug tip.
is too rare, My car was working well, I would say excellent, and you nomas install the rotor and rotor cap and failed, now I see that does not work, that disappointment.
Success !!!...
A friend lent me the "Ignition Coil", the response was immediate, the car feels smoother and changes come very well, "iddle speed" is held at 600-700 RPM, buy it and installed again, greetings to all and thanks for your support...
