im stuck on the side of the road with a code 6 15 43
All of this happen and my car will not start. It killed the car when I was driving. So I waited and the car turned back on. I could drive it half a mile or so and it will die and give me the same codes. Idk what to do to fix this.
Re: im stuck on the side of the road with a code 6 15 43
If you reset the ECU (remove 7.5A hood Back Up fuse for 3 minutes or more), do all three codes repeat after cranking the engine for 30 seconds? In general, only code 15 would prevent the engine from starting.
