92 Civic DX/b18c swap and wire tuck - won't start
so whenever i try to start the car it cranks and just kinda pops but doesn't start. but if i take the cap to the injector main relay off it'll start a little but then shut off once i touch the gas. i think its in the injector ground wires but prior to putting the harness in i tested all the wires and they were good. any help to this problem is greatly appreciated!
Re: b18c strange problem?
its in a 92 civic dx and yeah i rewired the engine harness to do a wire tuck which everything else seems to be working fine in the harness.
Re: 92 Civic DX/b18c swap and wire tuck - won't start
i'm thinking of the piece where all the injector ground wires come together in a plastic clip.
How many wires and what wire colors run to that plug? That's near the main relay? Are those the power wires for the injectors and IACV?
its 8 yellow/black wires. 4 of which go to the injectors, 1 to the IACV and 1 to the Tstat ground but i'm not sure of the other two anymore.
okay so i pulled my harness out again to test the wires for continuity and all of them were good. so check that off the list. i checked all my fuses and their all good also. i put it all back together and tried and the same problem. again it just sputters but if i take the cap (which has a metal piece inside to connect all the grounds to one) off the car will fire right up but run like poop and shut off?
Do the two fuses get voltage on the two top test tabs?
Did you resolder the main relay?
Here's a test:
Unplug the main relay and turn the key to ON(II). Then use a wire to jump terminal 1 (voltage from fuse 31) or 5 (voltage from fuse 24) to terminal 7 (fuel pump). Does this cause the fuel pump to run in both cases?
i think i may have found something tho. whenever i try to start it my CEL is staying lit. maybe bad ground to the ecu?
its tight and i just sanded it down a little to get a better contacting surface also but that didn't do anything. i'm thinking maybe the wire for the ground to the t-stat could be bad inside the harness. is there an easy way to test that?
well the main relay seems to be fine since the fuel pump is working and the injectors are too. but i tried adding a separate ground to the T-stat off the negative terminal but still same story. i'm running out of ideas!
