Del sol won't lock or unlock from outside
93 del sol si
Key won't turn on the outside of the drivers door. It locks from the inside and the passenger door locks and unlocks fine. Is there something I can spray in the key hole? Or other suggestions?
Thanks
Thanks
Re: Del sol won't lock or unlock from outside
Did a little fooling around with a spare lock from a donor door I have. The rubber on mine was chewed up causing the lock to get stuck in both directions on it, I used a sharp knife and pliers to cut away the excess chewed up material leaving the bare metal hook showing. A little dry lock lube in the upper part of the hook to lubricate it's inner parts of the lock a few times and then both outside and inside handle leavers starting opening the hook with ease. I sure hope this helps some people out I know I got a little frustrated putting another faulty one on my car before looking into that part a little more.
Apocolipse269
08-19-2004 05:44 PM
