Mounts the same eg/ek but different brackets?
I just pulled the d15b out of my buddies 1993 eg coupe and he just got a 94 GSR with no injectors, ecu, harness, linkage, or mounts. We do however have stock 99 si mounts (I think that's what they were in with it was in a ek coupe) and a ek coupe with a b20 vtec that has innovative motor mounts and brackets. My main question is are we able to use the d15b harness along with the ek mounts to put it in the eg with no problems? I read that the mounts are the same but the brackets were different. Thank you in advance for the help
H-T White Ops
Re: Mounts the same eg/ek but different brackets?
So is this what you're asking is possible?
Into an EG.
B18C1
D15B harness
EK B-series mounts
EK mounts don't fit in an EG iirc.
Into an EG.
B18C1
D15B harness
EK B-series mounts
Alright that's what I thought I was looking at the GSR and it has a wire coming out of the block near the crank pully and a wire coming out of the teanny, the d15b harness doesn't have this, should I just say fuxk it and get a b series vtec harness?
