Clorox In gas tank - starts with starting fluild
just bought a mint 93 eg ex of this hippy girl for 300. Ex boyfriend dumped clorox in her gas tank.
starts with starting fluild.
best way to fix this problem? lmk thx guys
H-T White Ops
Re: Clorox In gas tank
People are evil. I've never heard of anyone doing this before.
Would have been best if it hadn't been started.
http://www.ehow.com/about_5687159_ef...-gas-tank.html
Chemical Reaction
If bleach is poured into a gas tank, presumably with gas in it, the bleach itself will not harm the car. However, the chemical reaction between the chlorine in the bleach and the gasoline in the tank will definitely create havoc with your vehicle's fuel system and motor. The chlorine will react with the organic compounds from which gasoline is formed (remember, gas is refined oil and oil is an organic compound), creating an abnormal amount of rapid oxidation (rust). This reaction would, in effect, break down the metal in the gas tank dozens of years faster than normal. In fact, the adverse affects would become painfully obvious within two to four days.
Effects
If this reaction takes place and the car is not driven, repairing the damage may only involve the replacement of the damaged fuel tank and flushing the fuel system. However, if the car is driven, a mixture of bleach and fuel will be distributed throughout the fuel system, corroding all metal, rubber and plastic it comes into contact with. In addition, a high volume of rust sediment will be forced through the fuel injectors and into the engine. In the best cases, the fuel injectors will clog and no gas will get through to the engine. In the worst cases, some bleach-filled gasoline will enter the engine and affect enough of the engine to seize up the engine block, rendering it useless.
Effects
Well the engine seems to be fine... its runes fine with stater fuild into intake so really they engine seems to be fine
Get the fuel system flushed and see if that helps. If not, I'd start by replacing the main parts of the system, although the whole system needs to work as a whole to prevent any problems from occurring again in the future.
Re: Clorox In gas tank - starts with starting fluild
From the quote NOFX posted, it looks like you should really replace the fuel tank before any rust jacks up your fuel system/motor.
H-T White Ops
Might be worth removing the fuel pump and inspecting. I'd definitely drain the tank.
I'm not sure how bad this could be in the real world or how these cars in particular might react.
I'd have drained it first and not ran it until there's fresh gas at least.
About 1 month its been sitting, I im starting with flushing the tank,fuel rail,fueline,Tank, New gas filter
I like the tuna here
Damn, it sounds like the ex bf did his homework on what to dump into the tank. I would never have thought bleach would **** a car up like that.
I'm a fan of letting the air out of their tires, then crimping the valve stems. At least that doesn't run the risk of grenading a damn motor.
Oh look, I can change this
Don't forget that the fuel you drain is a powerful explosive ... ie., worse that just fuel on its own. More like a liquid bomb. Think about that next time you start it! Best do your work outside, and NOT under an awning.
It wouldn't be a bad idea to replace or seal the gas tank. They make a liquid sealant you can pour in and coat the inside. It would be cheaper than buying a new tank.
I read a little on the bleach/gasoline mix. It could create a peroxide. These are unstable compounds that can spontaneously catch fire or explode. One common peroxide is acetone peroxide, which is commonly referred to as "mother of satan". It's so unstable when wet that it can explode from crumbling under it's own weight as it dries. These aren't compounds to mess with.
H-T White Ops
In my experience, some 6th gens have the drain plug and some don't. We had a '97 CX without it and a '98 EX coupe with it. 1998 marked a lot of changes though.
H-T White Ops
Hard2Find
08-16-2004 08:47 PM
