Codes p1870, p0141, p1509, p1882 after swapping 99 D16Y5 and auto ECU into 5-speed
So i swamped out my mini me for a hx engine but i got the auto ecu and the auto wiring from the hx but i am running a manual tranny and i am curently in the progress of trying to get a manual ecu for the car but my problem is that when i start the car i have to keep the rpms at about 2k for about a min in cold weather or i bogs down and dies? any suggestion on what this could be cause i changed both of my o2 sensors
ecu
i think that i need a
so i got a 99 hx swaped over but it was from an auto so i got the auto wiring and the auto ecu so now i want to know if i need to get one of these and will i need to get a new wiring harness as well?
p2n-
A32 - 99-00 5sp
A33 - 99-00 5sp
L33 - 99-00 5sp
how hard are these to find and about what is the price range on them
p2n-
A32 - 99-00 5sp
A33 - 99-00 5sp
L33 - 99-00 5sp
Last edited by Former User; 01-07-2012 at 06:46 PM. Reason: Buying, selling, trading is forbidden in tech forums. Take it to the Marketplace when you are past trial user status.
Re: 99 hx problems
Your auto ECU is throwing the two P1800 codes because you have a manual transmission rather than an HX CVT.
I would assume that codes P0141 and P1509 are thrown because the secondary O2 sensor and IACV are disconnected. The latter is causing the idle problem.
Seagull Management
Re: 99 hx problems
Primary O2 also needs to be converted from a 4 wire to a 5 or 7 wire as well (manual HX primary O2 sensors are expensive in and around the $400 range IIRC, because they're a weird wideband O2)
Re: 99 hx problems
The egr is different as well from the auto and manual so if you convert to manual you will need to replace that as well, also all the 96-00 hx's were obd2a so any p2n from that range will work and the "L" series are the california ones.
Re: Codes p1870, p0141, p1509, p1882 after swapping 99 D16Y5 and auto ECU into 5-spee
The thing is that it is auto wiring in the car so both the o2 sensors are hooked up
OP, I 'm having that same issue. Is there a way to figure out if your ecu is for an auto. I'm a noob
98savage
05-02-2007 09:01 PM
