stumped on valve cover gasket leak.
i replaced the gasket and it leaked alot and then upon inspection i had a broke a mounting hole in half so i replaced rocker arm assembly and did everything to honda specs and the gasket still leaks but just when car is shut off or on a hill sideways does not leak as bad on level ground. the oil seeps out front pass side of valve cover. has new gaskets and the bolts are snug. what else could i do to stop this leak.?
Re: stumped on valve cover gasket leak.
no i did not but its not leaking by the cam caps but in front corner if i was goin to use rtv but was told not to bcuz it was a new gasket.
ok well i did a thin strip and then smoothed it out so and the the cam caps on the gasket cuz it was a tight fit so hopefully this will stop my leaking.
Don't go crazy torquing the cover down.
i put red rtv on all the cam corners in my cars never had a leak make sure your valvecover is not warped and your head is clean before installing the gasket
rallyeredem2
Honda Civic (2001 - 2005)
12-25-2014 10:58 AM
davidt1
04-04-2012 06:44 AM
E-spec Tuner
04-17-2003 09:16 AM
