b18c flywheel
b18c flywheel
those with gsr's, what flywheel would you guys go with, with an exedy organc clutch pushing about 180-190 whp?. CM, fidanza, ACT Prolite, comptech?
Re: b18c flywheel (luckyjun127)
I have had experience with both ClutchMaster lightweight flywheel and the ACT Xact 8.5lb racing flywheel. both are very nice and I honestly can't tell much of a difference between the two. So I would pick either one of those out of your choices
Re: b18c flywheel (lazy bum shaughn)
ive heard awesome things about the fidanza, same flywheel as the comptech but you can get them for like 250$ shipped through best buy forum.... under 8lbs.
many choices, whatever fits your budget. choice comes down to stock shaved piece, aluminium or chromoly. difference between 6.75-9/10lbs unit is next to impossible to tell.
stock shaved = no less then 12lbs when doen right and for safety
aluminum = fidanaza/cm and comptech all seem to be the same as far as quality (all are made by fidanza)
chromoly = Toda, Cusco, spoon, SRR, ACT all are great. with exception of SRR and ACT all seem to be more expensive then aluminum units.
from the one I used to have, it was next to impossible to tell the difference between a 12lbs and 8.5lbs chromoly units. :
Cusco
Toda
stock shaved unit to 12.75lbs
sotck shaved unit 11.25lbs
Cusco
Toda
Re: b18c flywheel (euclid)
i read the toda's horrible, that the teeth get all fucked up and the flywheel gets destroyed.
So yea, about that stalling out.
Re: b18c flywheel (Steve Berman)
I have the clutchmasters and it weighs in at a healthy 7.5lbs.
Same here!!! Definate Recomendation!
