98 EX door panels?
Re: 98 EX door panels? (siqcivic)
There's a screw next to the automatic window up/down switch, the rest you can pull off and when you pull, then I believe there is another screw ounce you pull off the part that has the automatic window control, its going to seem tough because there is all this glue/silicon around the edges of the door panals. Don't worry about breaking anything there is nothing really fragile.
Location: NOVA, but OC MD for the summers, 10th St., Tyson R.I.P, USA
There is one screw where the door handle is and another screw in the pocket on the armrest. Then just start pulling from the bottom left corner and work your way around, then just lift the door panel up and it will be off. Some of the clips might stay in the door, just pull them out and put them back in the door panel before you reinstall it.
schielej
11-14-2011 10:28 AM
finalclassic81
12-17-2008 01:12 PM
