engine bogs at full throttle?
Why does my 95 Honda civic DX bog out at full throttle? Acceleration is great but it bogs out if you put the pedal to the floor. TPS?
It has a JDM D15B SOHC VTEC engine.
Re: engine bogs at full throttle? (pc_doc_al)
Check your timing, try advancing it a little. Also check air filter and do you get a cel? Need more info...
Re: engine bogs at full throttle? (madhatch)
I'm running a P28 ECU. Short RAM Intake. Yes I'm getting a CEL. It seems to be a single Long blink that is continuous. Also it will not shift out of park without using the manual shift lock release. Are this sympthoms related?
I would say tha the short ram is the problem. My 98ex did the same with my old injen short ram. I ended up switching back to the stock air box with a k&n drop in filter and I've been much happier.
mine has done this since my d16z6 5sp install (engine may have been from auto originally).
dies when pedal is on the floor - fine at 99%.
dirty sanchez82
12
02-27-2008 05:37 AM
Rob Dizzle
10-08-2007 07:50 PM
Cuda70
12
08-16-2006 05:01 AM
1hotcivicSi
04-07-2004 01:22 PM
