Reverse Lights Not Working... 95 Coupe...
Alright... My reverse lights don't work, and I don't know why. I've checked the bulbs, fuses, and as much of the wiring as I could find, but I'm not seeing it... I've been told that it might be the switch that the stick connects with when in reverse, but I have no idea how to get to it. If someone could give me some info on how to get to it, and how to fix it, it'd be much appreciated.
Re: Reverse Lights Not Working... 95 Coupe... (B18PoweredCivic)
Yeah It's a plug at the top of the tranny that is attached to a 3 plug setup above the bleeding plug for the clutch. It's not a good description I'll look tomorrow when I can actually see. It's too late to actually go outside and look.
Re: Reverse Lights Not Working... 95 Coupe... (jigga008_99)
Alright, I've checked my Chilton's manual, scoured the transmission, clutch, and electrical sections, and came up with squat... Nothing about sensors on the tranny, or the button thingy doodad that gets pushed when you shift into reverse... Are there different names it might be under that I'm not recognizing?
Re: Reverse Lights Not Working... 95 Coupe... (ShakesTheKlown)
It should be near the starter...Theres only like 2 sensors by your trans...One is your Vehicle Speed Sensor and the other is that reverse sensor...Just make sure they are all connected flush together
[Modified by B18PoweredCivic, 8:28 PM 4/7/2003]
CHONCH
05-30-2002 05:58 PM
