finished exhaust install, got some questions
i just finished installing a RS*R cat-back exhaust on my 96 hatch. my questions are, the A-pipe does not have a shield around the pipe like my stock A-pipe did so will the heat cause any problems in that area? like with wires or combustable materials? fuel lines? 2nd question is if it is normal for condensation/water to leak from the dough-nut gasket/joint that is inbetween the A-pipe and the long section of pipe that runs under the car back to the muffler area that has the resonator on it? will this water leaking out from there do anything harmful? will it rust out the gasket or pipes and create an exhaust leak?
[Modified by deviant1, 5:39 PM 4/4/2003]
