need advice on mounts in a eg civic.
Guest
Posts: n/a
ok i have all teh integra mounts for my swap into a 93 eg cx. but the thign is all the mounts are good but the rear mount. the rear integra mount i have is completely torn up. i cant use it at all. now my question is b4 i go to the junk yard and grab another one. i need to know if i can use the stock civic cx rear mount i have. will it work??? i would still be using the integra rear mount bracket. any help would be aweseom thanx guys
Guest
Posts: n/a
Re: need advice on mounts in a eg civic. (Hybrid95CivicEX)
really i was told that swaping any b series motor that i had to use all integra mounts and the integra rear bracket. but i was also told that the stock CX mount with the integra rear bracket would possibly work. i am confused as to really what to do thanx for the reply. can u possible shed some light and dismiss the other things i been told because i really want to beleive you lol that would save me time and money if i could use the cx mount
Re: need advice on mounts in a eg civic. (hatchboy93)
u can use the civic cx mount and it will bolt up to the integra bracket w/ no problem.. the rear mounts are all the same.. some of the tranny and belt side mounts can be differnt depending on the year of the civic and what motor was installed.. for example we needed to get a gsr timing belt moutn for my roommates swap cause his dx mount was incorrect..
Guest
Posts: n/a
yea i got all the other mounts i got the integra side mount, the integra tranny nount and i also got the 2nd integra tranny mount and also got that other integra mount the one that bolts up to the chassis from the a/c bracket. are all the right mounts i need?
theturbocivic
11-22-2002 05:26 PM
