code 22 help
code 22 help
I am getting a code 22 which is the Vtec solenoid? Anyway I went from cx to si with a d16z6 and wired the noid to the ecu but still the code any ideas?
Re: code 22 help (lonefuzzy79)
which pin did you wire the solenoid to? have you wired the oil pressure as well and grounded it?
is the wire making contact?
Re: code 22 help (eg6ajk)
ok so I think then that my wiring is falling short. What wires need to go to what pins in the ECU. I have searched till I am blue in the face and still codes! Thanks
Also throwing Code 22
I'm also throwing Code 22.
Checked the vtec pressure switch and it's good.
I then checked the voltage for the blue/black wire and grounded the other pointer of the multimeter and only getting 1.03volts. The Helms says it should be close to 12v. I immediately checked the voltage at the battery and getting 12+.
It says to "Inspect for an open or short to ground in the wire between the VTEC pressure switch and the ECM (ECU) C15. If the wire is ok, substitute a known-good ECM and recheck"
Any ideas? Could it possibly be a bad ECU (OBD1 P72 is what I am using)?
I can try my friends ECU (same Hybrid).
Thanks!
Modified by Hybrid93Hatch at 11:03 AM 4/18/2003
Thanks!
mister2racer
10
07-01-2005 08:14 PM
ham
05-01-2005 10:57 PM
