Compression numbers on 97 civic EX
Re: Compression numbers on 97 civic EX (BlackB18CTeg)
anything between 160-200psi with less then 25psi spread between cylinders is acceptable.
minimum number is 135psi. anything lower and you got a problem.
Re: Compression numbers on 97 civic EX (eg6ajk)
well my compression thing wouldnt hold a compression number.... but i saw the needle go to 150 EVERY single cylinder.. is this normal?
Nisif
04-12-2005 09:13 AM
