Help! steering rack arms
Old 05-30-2003, 07:53 PM
oxSLEEPERxo's Avatar
Default Help! steering rack arms
How do you fix the steering rack arms to stop shooting out goo/greese? or do you have to replace the steering rack arms?
Old 05-30-2003, 09:31 PM
beeboyee's Avatar
Default Re: Help! steering rack arms (oxSLEEPERxo)
ahah i had the same problem
the best think to do is just replace the whole thing
ohh yea just in advance its called rack and pinion
just in case, cause the people at the junk yard
will bring out a diffrent part out
Old 05-30-2003, 09:34 PM
Future Texas Boy
vtecvoodoo's Avatar
I picked up a used manual rack for $30.
Old 05-30-2003, 10:50 PM
etmoron's Avatar
Default Re: Help! steering rack arms (vtecvoodoo)
had the same problem , damn junkyard told me 15o for the whole rack and pinion
Old 05-30-2003, 11:06 PM
beeboyee's Avatar
Default Re: Help! steering rack arms (etmoron)
daym 30 bucks? good ****!
i got my for 100, and it was power
as for installation i put that darn thing in and i still get no power steering
https://honda-tech.com/zerothread?id=515309
Old 05-31-2003, 04:59 AM
Default Re: Help! steering rack arms (beeboyee)
thanks for yall help
Old 05-31-2003, 05:03 AM
coseal's Avatar
you sure thats not cv joint grease comming from the inner joint of the cv axle? i have never seen a manual or power rack leak like that....
Old 05-31-2003, 06:01 AM
Default Re: Help! steering rack arms (coseal)
yea, it think its the rack and pinion because it is shooting out goo/greese all over the place.
Old 05-31-2003, 07:06 AM
Thanks for all the help. However, I got another questions. Is this a urgent matter that needs to be taken care of right away or can it wait 3 months.
Old 06-08-2003, 02:55 PM
bump
Old 06-08-2003, 03:02 PM
JDMy0's Avatar
i would look into fixing it asap... better safe than sorry
migs's Avatar
Its not urgent if you dont care about your steering rack. The part that ripped is called a bellow boot. Only way to replace those is to remove the tie rod ends. The rod end connects the rack to the steering knuckle.
Old 06-08-2003, 04:14 PM
Default Re: Help! steering rack arms (eeekay)
for the cv boot, i do not know if it is ripped or not. I have to jack up the car and check it to see.
Old 06-08-2003, 04:57 PM
s o h c's Avatar
just replaced the same boot today, took about 2 hours (with breaks here and there) and $20 for the boot and clips. the install is really easy and straight foward, unless the rack is damaged just replace the boot
Old 06-08-2003, 06:04 PM
Default Re: Help! steering rack arms (g unit)
g unit, was yours shooting out greese/goo also?
Old 06-08-2003, 07:53 PM
s o h c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo &raquo;</TD></TR><TR><TD CLASS="quote">g unit, was yours shooting out greese/goo also?</TD></TR></TABLE>
yes, grease and power steering fluid
Old 06-09-2003, 04:12 AM
thanks g unit, I will check today if the cv boot is ripped or anything.
Old 06-10-2003, 04:17 AM
i can't tell if it is ripped or not. G unit, how did you check if yours was ripped?
Old 06-10-2003, 02:10 PM
s o h c's Avatar
i just turned the boot a little and saw a very small slit in it. maybe try squeezing the boot and see if anything comes out
Old 06-10-2003, 02:46 PM
Nameless RB26's Avatar
Put a dab of rubber silicone on the hole after you clean it..
That's what I did with my axle boot and I've never had a problem..
Old 06-10-2003, 03:53 PM
Default Re: Help! steering rack arms (Nameless EJ6)
i will try squeezing it, see if any greese/goo comes out. Thanks nameless ej6, if i do find a rip in it, i will try use the method you used first, if it don't work i just replace it. thanks for responding
Old 06-10-2003, 04:01 PM
tvrsir's Avatar
DUDE!! THAT LOOKS TOTALLY LIKE THE INNER CV JOINT GREASE THAT's NOT THE STEeRING RACK. you should look it over carefully before changing it.
Old 06-10-2003, 04:25 PM
Turbo Powa's Avatar
Default Re: Help! steering rack arms (tvrsir)
if the rack and pinion boot is torn then you can just buy the boot at an auto store. If the axle boots are ripped you can either get a new boot and see what happens or you can change the axle. I would check all the boots and make sure its not torn first. If the axle boots are torn, I recommend you replace the whole axle.
Kevin Mason
03-06-2016 11:13 PM
fasterthanueg
Northwest (Sales)
11-30-2012 11:28 PM
88EFBOMB
Suspension & Brakes
03-05-2010 08:16 PM
Mohsin
10-07-2008 01:56 PM
an2ny888
05-27-2005 05:06 AM
Quick Reply: Help! steering rack arms
