Skunk2 camber kit installation
Yep, I did a search but got nothing.
How easy is it to put it a skunk2 camber kit. Any pointers or websites that I could look at for a guide?
Any help is appreciated. Thanks in advance!
Re: Skunk2 camber kit installation (sykol)
camber kits are not all that hard to put on. if you need help or a guide page to go buy search the web for camber kit installation alot of pages will pop up most are all the same.
Re: Skunk2 camber kit installation (CivicTunerB18)
i searched google.com too
what key words are best to search for?
ive tried "skunk2 camber kit install(ation)"
i can take some, dang i shoulda taken them when i installed
very easy
jack up car
take off wheel
take off upper castle nut
pound on control arm to pop the joint out
pop hood
take off the two nuts holding on the upper arm
pull out the arm
then the rest is self explanatory
then alignment for 29.95
very easy
jack up car
take off wheel
pop hood
pull out the arm
Re: Skunk2 camber kit installation (Turbo E)
You may have to remove some "junk" in the engine bay to gain access to the bolts... I think the battery and the cruise control/power steering stuff is in the way.
Re: Skunk2 camber kit installation (SpoonEK2)
can anyone provide info as to the quality and craftsman ship of this kit? Does it last long term? any probs with it slipping out of alignment? ? and does it provide adjustment for front and reaer or front only?
Re: Skunk2 camber kit installation (SpoonSportsJunkie)
ok i know this topic is a little, but i didn't feel like starting a new one. anyway, to the topic...
i flipped through this thread as well as others and found this website...
http://www.geocities.com/lx98c....html
i noticed that when he installed the kit, they used a tie-rod puller to seperate the ball joints. now my question is when you put everything back together with the kit installed, are there any special tools needed (i.e. balljoint press)? or can you just slide the 2 pieces together and tighten without the tool? please help.
thanks
thanks
Re: Skunk2 camber kit installation (One Slow Civic)
just tighten it back to spec and you are fine.
i got a front kit for my 95 EJ, and I have no complaints with the kit. Its perfect to use for those who have a slammed ride or just a slight drop...overall it gets a from me...and you can find some pretty good deals on the internet, like under $200 for the item and shipping (usually free shipping)....just to give you a heads-up...good luck...
MidwestSi
03-09-2005 04:15 PM
