Tach needle is bouncing around
Re: Tach needle is bouncing around (jdircksen)
was the cluster ever taken out?
if so, some screws might be loose
it happened to my buddy's temp gauge (working & not working)
Re: Tach needle is bouncing around (scratchline20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scratchline20 »</TD></TR><TR><TD CLASS="quote">The ignitor is inside the distributor. It has four? wires going to it. It's held to the housing with two small screws.</TD></TR></TABLE> new one'll run you bout $100 I think
yup. easiest thing is to take the distributor off, remove the cap and rotor, then unscrew the plate holding it down, remove the wires, then put the new one in and reverse the steps. good luck; just did it to mine so i know.
