water pump?
water pump?
what sound would a water pump make if it went bad...my motor is making a weird noise coming from that direction on that side of the motor...also every time i rev the motor the timing belt loosens up would this make a weird noise? could it be the tensoiner bolt?please let me know....im going krazy trying to figure this out...if anyone has an idea please let me know...
thanx alot
thanx alot
Re: water pump? (vxHATCHATTACK)
squeel like a pig. Also you will smell coolant
but sounds like your tensioner bering is gone if it loosens up your timing belt
Re: water pump? (Turbo E)
Sounds like its time to change your timing belt, belt tensioner, and water pump. It's best to do it all at once.
http://www.inlinefour.com/timingbeltkits.html
Re: water pump? (D16Z6racing)
[QUOTE=D16Z6racing]Sounds like its time to change your timing belt, belt tensioner, and water pump. It's best to do it all at once.
QUOTE]
That man is correct, best to replace everything at once because it is a PITA to get to it in the car, besides it saves having to do repetative work when you're to cheap or lazy to do it all at once and then something else goes out. While your at it you may want to check your front crank seal. it needs replacing from time to time.
QUOTE]
clys
02-07-2011 08:32 PM
B18C1NMotion
11-20-2007 11:27 AM
civic_tuned
23
07-26-2005 08:42 AM
1998hondaaccord
09-18-2003 07:25 AM
