what does it take to put a 99 si in 12s
just wondering how much hp's and tq's is it gonna take to make a 99 si to do 12sec passes? is it possible with my setup
my set up--
ls/vtec,
B18A block
stock B18A LS rods shot peenied
stock B18A pistons
Arp rod bolts
B16 head bolts
stock 93 B16A SiR2 head
stock vavletrain
comectics boost head gasket
STR block guard
GSR oil pump, water pump and timing belt
STR feul rail
SX Performance regulator
also got nuespeed springs
skunk2 cambers
Nitto 555R drag on Si wheels
Y21 LSD in a 99 si tranny
waiting to get a hondata to put my drag 3 kit on with Greddy type 24 IC and 440 RC injectors{hondata ain't cheap for obd2 cars}
to control boost i got a Apexi AVC-R
i am prolly going to get it tuned at RaVer Motorsport in Visalia
how much boost should i shoot for when i got to get it tuned?
Modified by EAZY at 6:16 AM 5/30/2003
my set up--
ls/vtec,
B18A block
stock B18A pistons
Arp rod bolts
B16 head bolts
stock vavletrain
STR block guard
STR feul rail
skunk2 cambers
Mr. Badwrench
Re: what does it take to put a 99 si in 12s (EAZY)
230 WHP put me 107mph in the 1/4. almost 80 in the 1/8th. traction shoulda put the car mid low 12's. that was 6 psi on a 9:1 engine. and that was also full audio in the trunk.
Re: what does it take to put a 99 si in 12s (boostedcivicsir)
man, thats the basically the same setup imma run(lsvtec) but mines will be in a hatch that weighs about 2200lbs with me in it...
on slicks and tuned i'll prolly tip 12s...
a diet is the key
heres my setup
b18a w\ctr pistons
b16a head PnP by LDL
itr dual valve springs
skunk2 stage 1
ITR manifold(soon)
gsr oil pump\water pump\t-belt
a diet is the key
heres my setup
b18a w\ctr pistons
skunk2 stage 1
ITR manifold(soon)
boostedcivicsir: 6 psi on a 9:1 engine, with tractions you wouldve hit mid to low 12s damn thats good
dohctorthrust: ? B18A with CTR pistons. is it an daily driven motor, isn't that kinda high for daily driven?
civicrights: you said get some real slicks, you talking bout wrinkle walls right, do they come in sizes to fit 15" Si rims?
Anybody know a good shop around the bay or valley in cali where i can get it tuned?
Here is an example of a car running 11's and capable of much more.
Here is a link to his 11/sec 1/4 Mile Run:
http://www.jcarsofindiana.com/...n.wmv
INFO IS AS FOLLOWS:
-93 Civic DX
Chassis:
-Ford Grabber Blue paint
-Amber corner lights
-Rota Sub Zero 15" wheels
-Kuhmo (R) Michelin (F) 205/50/15 tires
-Jamex struts
-Ground Control coilovers
-Skunk 2 upper control arms
-Competition Engeneering traction system
-ARP extended lug studs
-90 Integra rear disc brakes
-91 Civic LX 15/16 master cylinder
Drivetrain:
-96 USDM B18C1 swap
-Golden Eagle sleeves
-JE 9:1 .020 overbore pistons
-Eagle H-beam rods
-ARP head studs
-Crower dual valvesprings
-Crower Titanium retainers
-mild port work
-new oil pump, bearings, gaskets, ect.
-JG/Edelbrock intake manifold, polished
-Delphi injectors
-BJ's fuel rail
-BBK 70mm throttle body
-Indy Race Cores Radiator w/Spal fan
-Clutchmasters Twin Disc clutch kevlar/kevlar
-Clutchmasters flywheel made by Fidanza
-Accel plug wires
Turbo system:
-Turbonetics T-61 turbo w/ polished housing
-SFP race manifold
-Tial 40mm wastegate
-Tial blow off valve
-manual boost controller
-3" downpipe and upper intercooler pipe
-2.5" lower intercooler pipe
-Indy Race Cores intercooler
-3" Exhaust with Apex'i N1 muffler
Fuel System:
-Triangle Engeneering 10 gal. cell w/ sending unit
-Aeromotive 1000hp pump
-Aeromotive billet uluminum filter
-Aeromotive fuel pressure regulator
-Aeromotive pump voltage regulator
-Goodridge lines and fittings
-B&M fuel pressure gauge
Electronics and gauges:
-AEM EMS computer
-Greddy 60mm EGT gauge
-Autometer 30psi boost gauge
-VDO oil pressure gauge
-HKS turbo timer
-JDM EG6 gauge cluster
-MSD 6-BTM
-Blaster SS coil
Interior:
-97 Del sol seats blk/blk
-Honda audio accesory center console
-real carbon fiber gauge plate
-Razo baseball shift ****
The car made 528 hp and 363 tq at the wheels. Has ran 11.88 @ 126 on drag radials and pump gas on low boost.
Modified by Slow-R at 7:16 PM 5/30/2003
INFO IS AS FOLLOWS:
-93 Civic DX
Chassis:
-Jamex struts
Drivetrain:
-96 USDM B18C1 swap
-Eagle H-beam rods
-ARP head studs
-mild port work
-Delphi injectors
-BJ's fuel rail
-Accel plug wires
Turbo system:
-SFP race manifold
Fuel System:
-AEM EMS computer
-HKS turbo timer
-MSD 6-BTM
-Blaster SS coil
Interior:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EAZY »</TD></TR><TR><TD CLASS="quote">just wondering how much hp's and tq's is it gonna take to make a 99 si to do 12sec passes? is it possible with my setup
my set up--
ls/vtec,
B18A block
stock B18A pistons
Arp rod bolts
B16 head bolts
stock vavletrain
STR block guard
STR feul rail
skunk2 cambers
Modified by EAZY at 6:16 AM 5/30/2003</TD></TR></TABLE>as far as all motor goes, its ganna need alot more than this... or an overall weight of 1600 lbs
much higher compression and bigger cams is a start. with the turbo... no prob
my set up--
ls/vtec,
B18A block
stock B18A pistons
Arp rod bolts
B16 head bolts
stock vavletrain
STR block guard
STR feul rail
skunk2 cambers
1 Post
Re: what does it take to put a 99 si in 12s (DaBuccaneerFan2)
how many times did you blow up your motor?
unless it's BUILT...
go on a diet and get some nice set of cams(better valvetrain, pistons, PnP, TB, IM, etc, etc...)
and lotta powa w/no traction =
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaBuccaneerFan2 »</TD></TR><TR><TD CLASS="quote">13:0:1 compression w/200 shot of orange juice </TD></TR></TABLE>'
LMFAO, he said passES. With this setup I believe one pass is all you would be getting.
Re: what does it take to put a 99 si in 12s (Slow-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow-R »</TD></TR><TR><TD CLASS="quote">Here is an example of a car running 11's and capable of much more.
INFO IS AS FOLLOWS:
-93 Civic DX
Chassis:
-Jamex struts
Drivetrain:
-96 USDM B18C1 swap
-Eagle H-beam rods
-ARP head studs
-mild port work
-Delphi injectors
-BJ's fuel rail
-Accel plug wires
Turbo system:
-SFP race manifold
Fuel System:
-AEM EMS computer
-HKS turbo timer
-MSD 6-BTM
-Blaster SS coil
Interior:
Modified by Slow-R at 7:16 PM 5/30/2003</TD></TR></TABLE>
how low boost?
INFO IS AS FOLLOWS:
-93 Civic DX
Chassis:
-Jamex struts
Drivetrain:
-96 USDM B18C1 swap
-Eagle H-beam rods
-ARP head studs
-mild port work
-Delphi injectors
-BJ's fuel rail
-Accel plug wires
Turbo system:
-SFP race manifold
Fuel System:
-AEM EMS computer
-HKS turbo timer
-MSD 6-BTM
-Blaster SS coil
Interior:
how low boost?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow-R »</TD></TR><TR><TD CLASS="quote">8 Pds.</TD></TR></TABLE>
you mean 8 lbs.?
you mean 8 lbs.?
Banned
INFO IS AS FOLLOWS:
-93 Civic DX
Chassis:
-Jamex struts
Drivetrain:
-96 USDM B18C1 swap
-Eagle H-beam rods
-ARP head studs
-mild port work
-Delphi injectors
-BJ's fuel rail
-Accel plug wires
Turbo system:
-SFP race manifold
Fuel System:
-AEM EMS computer
-HKS turbo timer
-MSD 6-BTM
-Blaster SS coil
Interior:
This guy ran 11's on STREET Tires....... on slicks it would be in the 9's.... this setup is all you will ever need.
INFO IS AS FOLLOWS:
-93 Civic DX
Chassis:
-Jamex struts
Drivetrain:
-96 USDM B18C1 swap
-Eagle H-beam rods
-ARP head studs
-mild port work
-Delphi injectors
-BJ's fuel rail
-Accel plug wires
Turbo system:
-SFP race manifold
Fuel System:
-AEM EMS computer
-HKS turbo timer
-MSD 6-BTM
-Blaster SS coil
Interior:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">230 WHP put me 107mph in the 1/4. almost 80 in the 1/8th. traction shoulda put the car mid low 12's. that was 6 psi on a 9:1 engine. and that was also full audio in the trunk.</TD></TR></TABLE>
i have a stock itr 98spec in my 95 si
i hit 80.08 in the 1/8, but 98 in 1/4
4.7 fd
all at a crapy 14.1
bad 60'ers
4.7 fd
all at a crapy 14.1
bad 60'ers
Re: what does it take to put a 99 si in 12s (yayaRl337)
EASY the b18a with CTR's will be in the ball park of 12.1 to 12.5 depending on head gasket and milling
with mines its prolly gonna be around 12.3 or 12.4(my head is milled).... running 12.0 CR is still safe on pump gas...the guys on clubsi.com\naForum all do it...tunning is key!
if ctr's are too hihg of a compression for you try the jdm ITR pistons... then get some skunk 2 stage II's with it... agressive cams are the way to go with all motor cars... if not skunk's get some cams that are just as aggressive.
here is a link to a cam guide-clubsi.com\na forum
http://forums.clubsi.com/showf...art=1
my set up--
ls/vtec,
B18A block
stock B18A pistons
Arp rod bolts
B16 head bolts
stock vavletrain
STR block guard
quick ls/vtec question i thought b16 head bolts were too short and you needed gsr headbolts, i am building an ls/vtec and have passed up on brand new b16 arp headbolts beacause i was told they were too short and have been waiting for gsr headbolts. so do b16 headbolts fit?
my set up--
ls/vtec,
B18A block
stock B18A pistons
Arp rod bolts
B16 head bolts
stock vavletrain
STR block guard
Re: what does it take to put a 99 si in 12s (akumaracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akumaracer »</TD></TR><TR><TD CLASS="quote"> so do b16 headbolts fit?</TD></TR></TABLE>
my fitted, i use the same head bolts that was of the b16, but be carefull when you torque down the b16 head bolts, i broke one ofthe thread on the block by accidently over torqueing it and had to put heli coil in it, i guess the thread broke because the b16 head bolts is shorter
the b16a head studs ARE too short.. if compared side by side.. its about 7mm shorter then the b18c....
Hondizzle!
08-16-2005 04:36 AM
vtec_racer_2kgsr
13
06-07-2003 07:23 AM
