what is the quickest way to remove rear struts?
i can un bolt the thing easy, its just a matter of uncompressing the damper assembly. how do i do this without the aid of a spring compressor? need to send in a strut under warranty, and i dont have spring compressor on hand, nor the cash to rent one.
Re: what is the quickest way to remove rear struts? (neilff)
lay it on its side, step on the spring with your foot and start wrenching away. that should keep the spring from flying away. or just get a buddy to help you. that's how i did it.
Re: (jin_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jin_ »</TD></TR><TR><TD CLASS="quote">
lol
lol
Re: (neilff)
usually the strut piston will have a recess in the top of it that accepts an allen key (stock struts do this) or they make it six-pointed so you can use a wrench (koni yellows do this). that will stop the piston from spinning.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neilff »</TD></TR><TR><TD CLASS="quote">i can un bolt the thing easy, its just a matter of uncompressing the damper assembly. how do i do this without the aid of a spring compressor? need to send in a strut under warranty, and i dont have spring compressor on hand, nor the cash to rent one.</TD></TR></TABLE>
TO do it the ghetto way and hurting yourself or anything around you:
1) get old news paper and wrap it supe good and even duct tape the strut and upper mount to the paper so it won't fly away.
2) Then get a allen wrench and insert in the little opening at the top of the strut and turn the nut with an open end.
-or-
Just get a impact gun and zap it
-While doing this SIT OR STAND ON THE SPRING-
-or-
oddball327
07-15-2004 11:03 AM
