cheap alternative to replacing motor mounts
in that hella long post about SOHC upgrades i remember it used to say that you could use window cement or something like that to fill in the gaps in the motor mounts. Well i need to do something b/c my lower drivers side mount is shot. I was wondering if anyone has done this before, and how it has worked for them. Thanks
Re: cheap alternative to replacing motor mounts (thehatchninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja »</TD></TR><TR><TD CLASS="quote">in that hella long post about SOHC upgrades i remember it used to say that you could use window cement or something like that to fill in the gaps in the motor mounts. Well i need to do something b/c my lower drivers side mount is shot. I was wondering if anyone has done this before, and how it has worked for them. Thanks</TD></TR></TABLE>
Hhahaha! This thread freaked me out until I realized you were talking about the bushings, not the metal mount itself..... to me!!
Steve
Steve
Re: cheap alternative to replacing motor mounts (stevecockrill)
thanks a lot...i knew there was a way, do you think it's possible to do it without removing the mounts from the car, just squirt it in there and let it sit for 24 hours?
I to Smooch Pickle
anybody did that to the rear engine mount?? and if so, did it generate the same amount of vibration as a polyurethane one??
Rod.
12-31-2005 07:05 AM
