what tha...
Old 08-16-2003, 03:09 PM
Btothe3rdDegree's Avatar
Default what tha...
i go a 92 civic d15b7 and the oil pan leaks like a biotch! not those little spots in the driveways i mean big time, this is the third time i have replaced the gasket and it doesnt make a diiferance, the leak is on the tranny side i took the pan off and tried to feel for warpage but found nuttin, each time i put rtv on both sides of the gasket and it still leaks. i dont know if it matters but i have a bad o2 sensor that i am replacing and fautly fuel injectors which are all getting replaced. should i just get a new oil pan? ohh yeah it is not the O ring on the tranny side because the flywheel is very clean, no oil on it, whatcha guys think?
Old 08-16-2003, 03:12 PM
Filliam H. Muffman's Avatar
Default Re: what tha... (Btothe3rdDegree)
maybe its your oil filter?
or maybe....you can just go out and buy a new oil pan.
Old 08-16-2003, 03:22 PM
Risky Business
BauleyCivic's Avatar
Default Re: what tha... (JUN EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN EK9 &raquo;</TD></TR><TR><TD CLASS="quote">
or maybe....you can just go out and buy a new oil pan.</TD></TR></TABLE>
Old 08-16-2003, 03:30 PM
Solbros Owns Me
Evs-One's Avatar
Default Re: what tha... (BauleyCivic)
rear main seal G
Old 08-16-2003, 05:14 PM
TrickHonda98's Avatar
Default Re: what tha... (Emerika)
drain plug?
Old 08-16-2003, 05:26 PM
Default Re: what tha... (TrickHonda77)
no its above the drain plug, and i dont think it is the rear main seal because the flywheel is not full of oil, just the pan
Old 08-16-2003, 07:05 PM
aw1234dude's Avatar
When you put the rtv one the NEW GASKET, do you make sure that you clean both surfaces with some kind of alcohol so that you get a good seal and good contact?
Old 08-16-2003, 10:09 PM
Default Re: what tha... (aw1234dude)
yeah yeah they were so clean i could eat off of em, and no i didnt use two gaskets at the same time, i have gone throught three of them in total
JoshDoyle
12-25-2009 05:28 PM
wdissident
01-19-2009 08:49 PM
trooper0641
14
10-11-2005 07:11 PM
LAKER HATER
05-21-2004 07:51 AM
swlabhot
08-21-2003 04:38 AM
Quick Reply: what tha...
