Headlight condensation.....
I searched and found nothing. How do you stop the condensation on the headlights of a 96 hatchback? I was told that is why the inside of the lenses is 'yellowing'. The lights aren't very bright. Can I clean them or should I just buy new headlight assemblies? Thanks in advance!
Re: Headlight condensation..... (1fstazeg6)
water is leaking in somewhere...
I'd check to make sure there are no cracks in the housing or a harness off etc...
Then if all of that looked ok I'd through them in the oven for 20 mins or so at 250... then peel off the headlight lense and re-seal it with silicone adhesive...
search for a howto on blacking out your year headlights the procedure will be the same minus the painting of the insides...
man am I a sweetheart...
http://www.torontocivics.com/a....html
