(92-95) CX speedo swap into EX cluster anyone have tips or tricks???
Im picking up an EX cluster for my cx.
I want to keep the correct milleage.
Anyone have a how to on take the clusters apart, and anything i should be aware of when doing this swap?
PICS would be Awesome!
As always, thanks in advance!!
Re: (92-95) CX speedo swap into EX cluster anyone have tips or tricks??? (CIVIC dude)
its easy, just take off the plastic front, (3 push tabs at top of cluster) then on back of cluster behind speedo should be 3 gold colored screws. take them out and gently remove your speedo. (remember not to touch the needle!). repeat on other cluster and then swap them. if you need anything else, let me know. Done this atleast 5 times already with no problem
Re: (92-95) CX speedo swap into EX cluster anyone have tips or tricks??? (kwikEG)
Wow
Thanks for the Quick response!
My next question,
The CX cluster is Canadian.
The EX cluster is American.
Will my speedo read correctly once i swap it in??
Thanks
My next question,
Thanks
an ex cluster will fit in a dx perfectly, with the tach working, but i dont know about the cx to ex.
anyone else know about the Canadian / US cluster swap ?
WIll the cluster read properly with a swapped speedo or is the speedo determined else where?
i have a "honda of canada" civic hb and i swapped an ex cluster in it with no probs at all
Re: (92-95) CX speedo swap into EX cluster anyone have tips or tricks??? (92civeg)
how much rewiering is need to swap speedo's...is it hard? i really need an RPM guage on my CX.
anyone have directions that would help...thanks
also isn't rolling back the miles on a spedo a felony
Re: (92-95) CX speedo swap into EX cluster anyone have tips or tricks??? (93HatchCali)
Lost art of SEARCHING!!!
All 1992-1995 5th gen civic clusters will work on
any other 5th generation civics. If you want to
do your odometer swap the easy way then use
his instructions. If you actually want to have
the raised red line then you will need to take off
the needle. Its easy. Just be careful. Most people
use a fork and pry up evenly. I use pliers with a
90 degree bend and it gets it off there in a snap. It
is pretty straight forward from there.
Re: (92-95) CX speedo swap into EX cluster anyone have tips or tricks??? (d15dude)
everything on the speedometer will work except for the temp. gauge, well at least for me, but i have talked to alot of others whom had the same problem
Re: (92-95) CX speedo swap into EX cluster anyone have tips or tricks??? (Eibach95Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eibach95Civic »</TD></TR><TR><TD CLASS="quote">everything on the speedometer will work except for the temp. gauge, well at least for me, but i have talked to alot of others whom had the same problem</TD></TR></TABLE>
What car and what guage cluster?
if you swap a canadian speedo (KM/H) into a USDM cluster (MPH) i doubt the cluster will read correctly. i might be wrong, but i doubt it.
Re: (92-95) CX speedo swap into EX cluster anyone have tips or tricks??? (JUN EK9)
Doesnt speed get calculated somewhere else besides the speedo?
Isnt that what the speed sensor is for?
Anyone else have some insight on this?
THanks
THanks
My 92 cx is made in canuckda but cluster reads mph. I did the ex to cx swap and everything is fine except cruise control light comes up as the shift-up light. No biggie tho.
As far as the speedo gauge swap, it's very easy. Just dont drink too much coffee before doing that.
Re: (Zex_Nitrous)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zex_Nitrous »</TD></TR><TR><TD CLASS="quote">just swap both clusters instead of just the speedo</TD></TR></TABLE>
CANT!
the car is a Canadian CX i live in Canada.
The cluster i have is from a US EX.
I want to use the EX cluster with tach, but keep my origianl milleage and want the cluster to be in KM/H rather then MPH. I want to swap the CX's speedo into the EX housing with tach.
CANT!
Re: (CIVIC dude)
I cant believe I am seeing that people actually say that the speedo wont read right. They speed is collected at the tranny by your VSS. DUH. And the info is then sent to your gauge cluster. KmPH is not any different than MPH except that it is a different way of measuring the same thing. THUS the speedo will read correctly as it is moving the same amount of distance it just reads differently. I think I am going to put gh3y quotes on my cluster instead of MPH so that people wont understand...but then it might not read the same so
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CIVIC dude »</TD></TR><TR><TD CLASS="quote">anyone else know about the Canadian / US cluster swap ?
WIll the cluster read properly with a swapped speedo or is the speedo determined else where?</TD></TR></TABLE>
It will not matter. It reads the same. The only difference is the gauges face on it. I did a Ex cluster swap in my Dx and everything worked perfectly.
Re: (The Pastor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Pastor »</TD></TR><TR><TD CLASS="quote">just swap both clusters instead of just the speedo</TD></TR></TABLE>
How are you going to explain the wrong milage. That is just a dumb idea. You can even be fined for screwing around with a odometer .
#1 Super Guy
Re: (Bond)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bond »</TD></TR><TR><TD CLASS="quote">
How are you going to explain the wrong milage. That is just a dumb idea. You can even be fined for screwing around with a odometer .</TD></TR></TABLE>
If you really wanted to be evil, you could just unplug your VSS for a few months out of the year. Your speedo wouldn't work at that time though...
MotoCARR
11-24-2014 10:33 AM
dpine
04-06-2007 01:52 PM
tuanizdashtz
10
07-28-2005 11:21 AM
