No map Sensor? Is this right??
We are putting a B18a from a 93 teg into my friends 92 Civic hatch dx. Heres the problem.. his original motor had no map sensor. The engine harness off the stock 1.5 has a plug leftover around the throttle body with two wires for it. The map sensor on the B18a has a plug in for 3 wires. Is there a way these two connect somehow? If not then how do we hook this map sensor up? Thanks for help.
ImprtRcr02
ImprtRcr02
Re: No map Sensor? Is this right?? (ImprtRcr02)
All MAP sensors use 3 wires: Power, Ground, and Output.
Not sure what your 2 wire connector is for, but it ain't the MAP. What are the wire colors?
Re: No map Sensor? Is this right?? (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">All MAP sensors use 3 wires: Power, Ground, and Output.
Exactly
Exactly
Re: No map Sensor? Is this right?? (Jay De Em)
I cant remember exactly what colors they were, I think one might have been blue/yellow and the other maybe green/?? Well then the original motor never had a map sensor on it if its 3 wires. I need to know how to hook up the map on the new motor. Anyone run into this problem?
ImprtRcr02
ImprtRcr02
the map sensor plug on the dx hatches are located on the firewall near the batter...should look like a random plug coming off the firewall..
hondaeg8
06-22-2005 03:03 PM
